[gdal-dev] Kakadu Jpeg2000 driver
Tamas Szekeres szekerest at gmail.com
Wed Nov 2 14:42:25 EDT 2011
This sounds like a driver specific problem. Do you have some test data to
reproduce this?
Best regards,
Tamas
2011/11/2 Livneh Yehiyam <yehil at rafael.co.il>
>   Hi****
> I'm trying to use the Kakadu Jpeg2000 (JP2KAK) driver to read raster data.
> I'm working on windows7 64 bit with gdal source version 1.8.1****
> I've compiled the Kakadu SDK version v6.0 (v6_0-00828N), and compiled Gdal
> with the driver enabled. I'm using the c# binding.****
> I can open the dataset, and everything looks ok (size, number of
> overviews, band count etc.).****
> When I read data from one of the bands at the base resolution (lets say it
> is 512x512) I get the correct data.****
> Band mainBand = dataset.GetRasterBand(1);****
> mainBand.ReadRaster(0,0,512,512,buffer,512,512,DataType.GDT_Byte,4,2048);*
> If I get one of the overview bands:****
> Band overviewBand = mainBand.GetOverview(0);****
> And I try to read the entire band (lets say it is 256x256):****
> overviewBand.ReadRaster(0,0,256,256,buffer,256,256,DataType.GDT_Byte,4,1024);
> What I get in the buffer are the first 256x256 pixels of the mainBand.****
> This is contrary to the behavior I'm used to get when reading GTiff files,
> or even JPEG2000 with the JP2ECW driver.****
> Is this behavior by design, or is there another way to achieve what I want.
> Thanks****
> Yehiyam****
> * This message (including any attachments) issued by RAFAEL- ADVANCED
> DEFENSE SYSTEMS LTD. (hereinafter "RAFAEL") contains confidential
> information intended for a specific individual and purpose, may constitute
> information that is privileged or confidential or otherwise protected from
> disclosure. If you are not the intended recipient, you should contact us
> immediately and thereafter delete this message from your system. You are
> hereby notified that any disclosure, copying, dissemination, distribution
> or forwarding of this message, or the taking of any action based on it, is
> strictly prohibited. If you have received this e-mail in error, please
> notify us immediately by e-mail mailto:lawraf at rafael.co.il and completely
> delete or destroy any and all electronic or other copies of the original
> message and any attachments thereof. *
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111102/18f10b6a/attachment.html
