[gdal-dev] probles by ecw-convert (gdal_translate and expand)
Jan Tappenbeck tappenbeck at widemann.de
Thu Nov 3 06:23:57 EDT 2011
hi !
i had cit-files (microstation) to convert into ecw.
in the first step i transform into tiff by:
gdal_translate -of GTiff  image.cit image.tif
if i get the image-properties by gdalinfo i get following:
C:\Program Files (x86)\FWTools2.4.7>gdalinfo
"D:\Duelmen\Musterdaten\g8744-1.tif
Driver: GTiff/GeoTIFF
Files: [pATH]\g8744-1.tif
Size is 16002, 8619
Coordinate System is `'
Origin = (-947485262.477377770000000,-1221704414.522622100000000)
Pixel Size = (3224.954755655543500,-3224.954755655543500)
Image Structure Metadata:
   INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (-947485262.477,-1221704414.523)
Lower Left  (-947485262.477,-1249500299.562)
Upper Right (-895879536.477,-1221704414.523)
Lower Right (-895879536.477,-1249500299.562)
Center      (-921682399.477,-1235602357.042)
Band 1 Block=16002x1 Type=Byte, ColorInterp=Palette
   Color Table (RGB with 256 entries)
     0: 255,255,255,255
     1: 0,0,0,255
   255: 0,0,0,255
   the image in preview is ok !
   now i convert into ecw by:
   gdal_translate -of ECW image.tif image.ecw
   after start the command i get the information:
   Input file size is 16002, 8619
Warning 6: ECW driver ignores color table. The source raster band will
be consid
ered as grey level.
Consider using color table expansion (-expand option in gdal_translate)
0...10...20...30...40...50...60...70...80...90...100 - done.
   but now  !  the image is only BLACK !!!!
   can andyone tell me how the command had to be for
   "Consider using color table expansion (-expand option in
gdal_translate)" ???
   regards Jan :-)
