[gdal-dev] Debug/Release configuration on Visual
G. Allegri giohappy at gmail.com
Thu Nov 3 09:49:17 EDT 2011
I don't know exactly what the Debug build does, but AFAIK it incorporates
the symbolic debug information inside the compiled object, layouts a
different assembly, and links against the debug runtime, but from the point
of view of common debugging (breakpoints, inspecting properties, etc.) I
don't see differences with a Release + debug informations (which I suppose
is made available thorugh the .pdb files).
giovanni
2011/11/3 QUILLET Jean-Charles <jean-charles.quillet at alyotech.fr>
>   *De la part de* G. Allegri
> *Envoyé :* jeudi 3 novembre 2011 13:29
> I find very useful, for common debugging of C++ apps, to build in Release
> mode (/MD) but with debugging infos (/Zi) and removing optimization (/Od).
> With this flags I'm able to debug my app but I don't need to link against
> Debug libraries.****
> That's very interesting. That would be the way to go for me. It didn't
> know this was possible. I'll try this out. ****
> Thanks for the hint ! ****
> What the point of using this debug mode then: I mean this flag /MDd ?****
> Jean-Charles****
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111103/c5790a19/attachment.html
