[gdal-dev] OGR to access s57 file, missing attributes issue
sjtuDNA luqi.cg at gmail.com
Fri Nov 4 04:11:53 EDT 2011
Hi all,
    I'm now interesting in displaying ENCs. I've also read lots of ideas
from this site.
    Now, I got some promising results but not enough for displaying an ENC.
    I got info from :
http://osgeo-org.1803224.n2.nabble.com/OGR-about-s-57-td3561320.html
    and from
http://osgeo-org.1803224.n2.nabble.com/OGR-to-access-s57-file-td2026900.html
    This is exactly the problem I met. Sr. Frank Warmerdam dump an layer
named WRECKS in an S-57 dataset.
And the features look like :
OGRFeature(WRECKS):2163
   RCID (Integer) = 2164
   PRIM (Integer) = 1
   GRUP (Integer) = 2
   OBJL (Integer) = 159
   RVER (Integer) = 1
   AGEN (Integer) = 540
   FIDN (Integer) = 2135161787
   FIDS (Integer) = 688
   LNAM (String) = 021C7F43FBBB02B0
   LNAM_REFS (StringList) = (null)
   FFPT_RIND (IntegerList) = (null)
   CATWRK (Integer) = 1
   CONRAD (Integer) = (null)
   CONVIS (Integer) = (null)
   EXPSOU (Integer) = (null)
   HEIGHT (Real) = (null)
   NOBJNM (String) = (null)
   OBJNAM (String) = (null)
   QUASOU (String) = 2
   SOUACC (Real) = (null)
   STATUS (String) = (null)
   TECSOU (String) = (null)
   VALSOU (Real) = (null)
   VERACC (Real) = (null)
   VERDAT (Integer) = (null)
   VERLEN (Real) = (null)
   WATLEV (Integer) = 3
   INFORM (String) = (null)
   NINFOM (String) = (null)
   NTXTDS (String) = (null)
   SCAMAX (Integer) = (null)
   SCAMIN (Integer) = (null)
   TXTDSC (String) = (null)
   RECDAT (String) = (null)
   RECIND (String) = (null)
   SORDAT (String) = (null)
   SORIND (String) = (null)
   POINT (61.1031909 -32.4450159)
    My problem is when i use the following code to dump an layer's feature i
cannot get the attributes under the "-----" line.
    I've also turned on the environment variables like RETURN_LINKAGES,
RETURN_PRIMITIVES and etc. Thus, I got the attributes:
  ORNT (IntegerList) = (1:255)
  USAG (IntegerList) = (1:255)
  MASK (IntegerList) = (1:255)
    However, I just cannot get the attributes below MASK. I'm this close to
link the OGR/S57 data with S52 for rendering.
    Can I get some help with this?  Thanks in advance!
rgds,
Qi.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/OGR-to-access-s57-file-missing-attributes-issue-tp6961974p6961974.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
