[gdal-dev] OGR to access s57 file, missing attributes issue
s duclos sylvain_duclos at yahoo.com
Fri Nov 4 12:05:24 EDT 2011
sjtuDNA,
I gather that you want to render your ENC in S52
The S52 code live at http://openev.cvs.sourceforge.net/viewvc/openev/contrib/S52/
Try to build s52glx target (minimal deps).
rgds,
Sylvain.
----- Original Message -----
> From: sjtuDNA <luqi.cg at gmail.com>
> To: gdal-dev at lists.osgeo.org
> Cc:
> Sent: Friday, November 4, 2011 4:11:53 AM
> Subject: [gdal-dev] OGR to access s57 file, missing attributes issue
> Hi all,
>     I'm now interesting in displaying ENCs. I've also read lots of ideas
> from this site.
>     Now, I got some promising results but not enough for displaying an ENC.
>     I got info from :
> http://osgeo-org.1803224.n2.nabble.com/OGR-about-s-57-td3561320.html
>     and from
> http://osgeo-org.1803224.n2.nabble.com/OGR-to-access-s57-file-td2026900.html
>     This is exactly the problem I met. Sr. Frank Warmerdam dump an layer
> named WRECKS in an S-57 dataset.
> And the features look like :
> OGRFeature(WRECKS):2163
>    RCID (Integer) = 2164
>    PRIM (Integer) = 1
>    GRUP (Integer) = 2
>    OBJL (Integer) = 159
>    RVER (Integer) = 1
>    AGEN (Integer) = 540
>    FIDN (Integer) = 2135161787
>    FIDS (Integer) = 688
>    LNAM (String) = 021C7F43FBBB02B0
>    LNAM_REFS (StringList) = (null)
>    FFPT_RIND (IntegerList) = (null)
>    CATWRK (Integer) = 1
>    CONRAD (Integer) = (null)
>    CONVIS (Integer) = (null)
>    EXPSOU (Integer) = (null)
>    HEIGHT (Real) = (null)
>    NOBJNM (String) = (null)
>    OBJNAM (String) = (null)
>    QUASOU (String) = 2
>    SOUACC (Real) = (null)
>    STATUS (String) = (null)
>    TECSOU (String) = (null)
>    VALSOU (Real) = (null)
>    VERACC (Real) = (null)
>    VERDAT (Integer) = (null)
>    VERLEN (Real) = (null)
>    WATLEV (Integer) = 3
>    INFORM (String) = (null)
>    NINFOM (String) = (null)
>    NTXTDS (String) = (null)
>    SCAMAX (Integer) = (null)
>    SCAMIN (Integer) = (null)
>    TXTDSC (String) = (null)
>    RECDAT (String) = (null)
>    RECIND (String) = (null)
>    SORDAT (String) = (null)
>    SORIND (String) = (null)
>    POINT (61.1031909 -32.4450159)
>     My problem is when i use the following code to dump an layer's feature i
> cannot get the attributes under the "-----" line.
>     I've also turned on the environment variables like RETURN_LINKAGES,
> RETURN_PRIMITIVES and etc. Thus, I got the attributes:
>   ORNT (IntegerList) = (1:255)
>   USAG (IntegerList) = (1:255)
>   MASK (IntegerList) = (1:255)
>     However, I just cannot get the attributes below MASK. I'm this close to
> link the OGR/S57 data with S52 for rendering.
>     Can I get some help with this?  Thanks in advance!
> rgds,
> Qi.
> http://osgeo-org.1803224.n2.nabble.com/OGR-to-access-s57-file-missing-attributes-issue-tp6961974p6961974.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
