[gdal-dev] Patch for s57reader.cpp
Etienne Tourigny etourigny.dev at gmail.com
Fri Nov 4 14:54:09 EDT 2011
Dear  Mike,
Please add this to a relevant ticket, or create one and add it there.
http://trac.osgeo.org/gdal/report
thanks, Etienne
On Fri, Nov 4, 2011 at 4:27 PM,  <mrxonx at hotmail.com> wrote:
> Dear all,
> Included is a patch for s57reader.cpp that properly applies updates for
> certain types of charts.
> The essence of this patch is that SG2D field may not be present in
> original record, and must be added if update is trying to insert SG2D
> fields.
> The patch was made against our modified version of OGR, so line numbers
> likely do not match and certain function signatures may need to be
> updated. If you'd like to apply it - make sure it goes in the
> S57Reader::ApplyRecordUpdate.
> Best,
> Mike
> Index: s57reader.cpp
> --- s57reader.cpp       (revision 0000)
> +++ s57reader.cpp       (working copy)
> @@ -2635,16 +2635,30 @@
>         /* If we don't have SG2D, check for SG3D */
>         if( poDstSG2D == NULL )
> -            poSrcSG2D = poUpdate->FindField("SG3D");
>             poDstSG2D = poTarget->FindField("SG3D");
> +            if (poDstSG2D != NULL) {
> +               poSrcSG2D = poUpdate->FindField("SG3D");
> -        if( (poSrcSG2D == NULL && nCCUI != 2) || poDstSG2D == NULL )
> +        if( (poSrcSG2D == NULL && nCCUI != 2) || (poDstSG2D == NULL && nCCUI != 1) )
>             CPLAssert( FALSE );
>             return FALSE;
> +        if (poDstSG2D == NULL) {
> +          poTarget->AddField(poTarget->GetModule()->FindFieldDefn("SG2D"));
> +          poDstSG2D = poTarget->FindField("SG2D");
> +            CPLAssert( FALSE );
> +            return FALSE;
> +          // Delete null default data that was created
> +          poTarget->SetFieldRaw( poDstSG2D, 0, NULL, 0 );
>         nCoordSize = poDstSG2D->GetFieldDefn()->GetFixedWidth();
>         if( nCCUI == 1 ) /* INSERT */
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
