Re: [gdal-dev] Aster tif files to hgt
Jaromír Mikeš mira.mikes at seznam.cz
Sun Nov 6 10:46:41 EST 2011
> Od: Scott Arko <saarko at alaska.edu>
Hello Scott
> You should be able to convert directly to this format with gdal_translate.
> Something like
> gdal_translate -of SRTMHGT input.tif output.hgt
> I have done this in the past to convert to the SRTM format and it has
> worked fine.
Conversion works fine, thank you.
Only issue is that srmt2osm program generate highest peaks 7500m for area where is max high 2500m ;(
Maybe problem with different resolution between srtm and aster data?
Or some weird artifacts?
I will finish map this night so I will see more then
regards
mira
