[gdal-dev] add tranperency
Chaitanya kumar CH chaitanya.ch at gmail.com
Mon Nov 7 13:36:22 EST 2011
Jan,
You can use the -srcnodata and -dstalpha options of gdalwarp[1] to set
nodata values and create an alpha band to the image. You will have to give
the value of the black borders with the -srcnodata option.
[1]: http://www.gdal.org/gdalwarp.html
On Mon, Nov 7, 2011 at 5:33 PM, Jan Tappenbeck <tappenbeck at widemann.de>wrote:
>  Hi !
> i have a image with following data:
> C:\Program Files (x86)\FWTools2.4.7>gdalinfo "[Path]\trans_a.tif"
> Driver: GTiff/GeoTIFF
> Files: D:\brumi\VG_Bruchmuehlbach-**Miesau_DOP\geotiff\trans_a.tif
> Size is 10390, 10390
> Coordinate System is:
> PROJCS["DHDN / 3-degree Gauss-Kruger zone 2",
>    GEOGCS["DHDN",
>        DATUM["Deutsches_**Hauptdreiecksnetz",
>            SPHEROID["Bessel 1841",6377397.155,299.**1528128000009,
>                AUTHORITY["EPSG","7004"]],
>            AUTHORITY["EPSG","6314"]],
>        PRIMEM["Greenwich",0],
>        UNIT["degree",0.**0174532925199433],
>        AUTHORITY["EPSG","4314"]],
>    PROJECTION["Transverse_**Mercator"],
>    PARAMETER["latitude_of_origin"**,0],
>    PARAMETER["central_meridian",**6],
>    PARAMETER["scale_factor",1],
>    PARAMETER["false_easting",**2500000],
>    PARAMETER["false_northing",0],
>    UNIT["metre",1,
>        AUTHORITY["EPSG","9001"]],
>    AUTHORITY["EPSG","31466"]]
> Origin = (2601576.178792405400000,**5477422.986974134100000)
> Pixel Size = (0.200049845331526,-0.**200049845331526)
> Metadata:
>  AREA_OR_POINT=Area
> Image Structure Metadata:
>  INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left  ( 2601576.179, 5477422.987) (  7d24'1.33"E, 49d25'34.75"N)
> Lower Left  ( 2601576.179, 5475344.469) (  7d23'59.41"E, 49d24'27.48"N)
> Upper Right ( 2603654.697, 5477422.987) (  7d25'44.45"E, 49d25'33.49"N)
> Lower Right ( 2603654.697, 5475344.469) (  7d25'42.50"E, 49d24'26.22"N)
> Center      ( 2602615.438, 5476383.728) (  7d24'51.92"E, 49d25'0.49"N)
> Band 1 Block=10390x1 Type=Byte, ColorInterp=Red
> Band 2 Block=10390x1 Type=Byte, ColorInterp=Green
> Band 3 Block=10390x1 Type=Byte, ColorInterp=Blue
> there are black arrows at the border (by transformation) - is it possible
> to make i transparency ?
> how?
> gdal_translate -of ECW old_image.tif new_image.ecw
> tells that is unpossible !!!
> can you help me ?
> regards Jan :-)
> ______________________________**_________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/gdal-dev<http://lists.osgeo.org/mailman/listinfo/gdal-dev>
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111108/0894cdcd/attachment.html
