[gdal-dev] Re: OGR to access s57 file, missing attributes issue
sjtuDNA luqi.cg at gmail.com
Tue Nov 8 00:46:33 EST 2011
Finally I got whats wrong with my code.
The problem is :
The S-57 reader depends on having two supporting files,
s57objectclasses.csv, and s57attributes.csv available at runtime in order to
translate features in an object class specific manner. These should be in
the directory pointed to by the environment variable S57_CSV, or in the
current working directory.
By setting environment variable S57_CSV, i get the additional layers.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/OGR-to-access-s57-file-missing-attributes-issue-tp6961974p6973258.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
