[gdal-dev] Re: lost GeoTiff file metadata with gdalwarp
fred p mapoubelle22 at gmail.com
Thu Nov 10 11:45:44 EST 2011
I have applied the following patch for my own needs to gdalwarp.cpp (from
release 1.8.1). Maybe could it be applied in the next release with the
appropriate changes?
Thanks for your answers.
791a792,818
> /*      Get the metadata of the first source file if it is a GeoTiff    */
> /*      and apply them to the destination file.                         */
>         if ( iSrc==0 && pszFormat == "GTiff")
>             char **metadataSet=NULL;
>             metadataSet = GDALGetMetadata(hSrcDS, "");
>             if( CSLCount(metadataSet) > 0 )
>                 for( i = 0; metadataSet[i] != NULL; i++ )
>                     char *val = CPLStrdup(strstr(metadataSet[i],"=")+1);
>                     size_t lenkey = strlen(metadataSet[i])-strlen(val);
>                     char *key = (char*)malloc(lenkey);
>                     strncpy(key, metadataSet[i], lenkey);
>                     key[lenkey-1] = '\0';
>                     if( GDALSetMetadataItem(hDstDS, key, val, NULL) !=
CE_None ){
>                         fprintf( stderr, "Ecriture du tag %s impossible",
key);
Le 10 novembre 2011 13:40, fred p <mapoubelle22 at gmail.com> a écrit :
> Hello list !
> I use the gdalwarp tool to change the projection of a GeoTiff file but the
> most of the metadata of the source file are lost, which is not the case
> with the gdal_translate tool.
> Particularly, the following metadata are lost :
>   TIFFTAG_DOCUMENTNAME
>   TIFFTAG_IMAGEDESCRIPTION
>   TIFFTAG_SOFTWARE
>   TIFFTAG_DATETIME
>   TIFFTAG_ARTIST
>   TIFFTAG_HOSTCOMPUTER
> Do I miss something ?
> The command :
> gdalwarp -t_srs EPSG:4326 srcfile.tif outfile.tif
> The gdalinfo output on the source file, followed by the gdalinfo output on
> the output file :
> Driver: GTiff/GeoTIFF
> Files: srcfile.tif
> Size is 2500, 2500
> Coordinate System is:
> PROJCS["Geostationary_Satellite",
>     GEOGCS["GCS_unnamed ellipse",
>         DATUM["D_unknown",
>             SPHEROID["Unknown",6378160,298.2539162964669]],
>         PRIMEM["Greenwich",0],
>         UNIT["Degree",0.017453292519943295]],
>     PROJECTION["Geostationary_Satellite"],
>     PARAMETER["central_meridian",57],
>     PARAMETER["satellite_height",35785846.6396],
>     PARAMETER["false_easting",0],
>     PARAMETER["false_northing",0],
>     UNIT["Meter",1]]
> Origin = (-5620805.668447489850223,5620805.668447489850223)
> Pixel Size = (4496.644534757992005,-4496.644534757992005)
> Metadata:
>   TIFFTAG_DOCUMENTNAME=documentname
>   TIFFTAG_IMAGEDESCRIPTION=productidentification={
>         "observedProperty":"observedProperty",
>         "process":"process",
>   TIFFTAG_SOFTWARE=software
>   TIFFTAG_DATETIME=2011:11:10 11:00:00
>   TIFFTAG_ARTIST=artist
>   TIFFTAG_HOSTCOMPUTER=computer
>   AREA_OR_POINT=Area
> Image Structure Metadata:
>   COMPRESSION=JPEG
>   INTERLEAVE=BAND
> Corner Coordinates:
> ERROR 1: tolerance condition error
> Upper Left  (-5620805.668, 5620805.668)
> Lower Left  (-5620805.668,-5620805.668)
> Upper Right ( 5620805.668, 5620805.668)
> Lower Right ( 5620805.668,-5620805.668)
> Center      (   0.0000000,   0.0000000) ( 57d 0'0.00"E,  0d 0'0.01"N)
> Band 1 Block=2500x1 Type=Byte, ColorInterp=Gray
> The gdalinfo output on the output file :
> Files: outfile.tif
> Size is 1673, 1673
> GEOGCS["WGS 84",
>     DATUM["WGS_1984",
>         SPHEROID["WGS 84",6378137,298.257223563,
>             AUTHORITY["EPSG","7030"]],
>         AUTHORITY["EPSG","6326"]],
>     UNIT["degree",0.0174532925199433],
>     AUTHORITY["EPSG","4326"]]
> Origin = (0.000000000000000,70.000000000000000)
> Pixel Size = (0.059772863120143,-0.059772863120143)
> Metadata:
>   AREA_OR_POINT=Area
>   INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (   0.0000000,  70.0000000) (  0d 0'0.01"E, 70d 0'0.00"N)
> Lower Left  (   0.0000000, -30.0000000) (  0d 0'0.01"E, 30d 0'0.00"S)
> Upper Right ( 100.0000000,  70.0000000) (100d 0'0.00"E, 70d 0'0.00"N)
> Lower Right ( 100.0000000, -30.0000000) (100d 0'0.00"E, 30d 0'0.00"S)
> Center      (  50.0000000,  20.0000000) ( 50d 0'0.00"E, 20d 0'0.00"N)
> Band 1 Block=1673x4 Type=Byte, ColorInterp=Gray
> <http://int.ask.com/web?siteid=10000861&webqsrc=999&l=dis&q=dust%20RGB%20composite>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111110/7851fdcd/attachment.html
