[gdal-dev] Help from MapInfo users, please
Zoltan Szecsei zoltans at geograph.co.za
Fri Nov 11 03:11:13 EST 2011
Skipped content of type multipart/alternative-------------- next part --------------
Type: audio/mid
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111111/12ab19ba/xxx-0001.bin
Version 450
Charset	"WindowsLatin1"
Delimiter	","
'Please include coordinate system information below if coordinates are not in degrees.
'E.g. if the coordinates are in meters, the coordinate system is projected, and the projection algorithm is
'State Plane Coordinate System 1983 (102 - Alabama West)' using the datum
'North American 1983', then the coordinate system information should be set to
'CoordSys Earth Projection 8, 74, 'm', -87.5, 30.0, 0.9999333333, 600000, 0'
Columns	25
FEAT_TYPE_ID	Smallint
OPERATIONAL_STATUS_ID	Smallint
JOB_NR	Char(30)
EST_REVISION_DATE	Date
GID	Integer
CUID	Char(35)
FEATURE_RELIABILITY_DATE	Date
ATTR_RELIABILITY_DATE	Date
CAPTURE_SOURCE_TYPE_ID	Smallint
CAPTURE_METHOD_ID	Smallint
SOURCE_DESCRIPTION	Char(254)
SOURCE_CURRENCY	Date
SOURCE_ACCURACY	Decimal(20,6)
ENTITY_NAME	Char(50)
GEOMETRY_TYPE	Char(5)
OLD_GDO_GID	Decimal(20,6)
WHEN_UPDATED	Date
LOCKED_FLAG	Decimal(20,6)
AUD_LAST_USER	Char(30)
AUD_LAST_DATE	Date
SDO_GTYPE	Smallint
LTT_FEATURE_ID	Integer
LTT_STATUS	Char(2)
LTT_CURRENT_REVSET_ID	Integer
ID1	Integer
Data
Pline  11
29.95673988356700	-28.40662240625970
29.95718006098160	-28.40676240209660
29.95738632434000	-28.40699700213080
29.95750121201020	-28.40744778705080
29.95755122269710	-28.40787061539590
29.95743034048500	-28.40839910570730
29.95685343230360	-28.40886137413540
29.95624411438540	-28.40921278552040
29.95535250168890	-28.40960783056550
29.95480735870450	-28.41011152351530
29.95440862252880	-28.41047465801490
Pline  14
29.94791348401000	-28.39460556404870
29.94812021583970	-28.39634236132940
29.94819167371380	-28.39731383634100
29.94840531609780	-28.39838151857050
29.94871243378850	-28.39936523739210
29.94931728142230	-28.40027745421180
29.95020602100940	-28.40132654109880
29.95256989308940	-28.40401766428030
29.95395257704750	-28.40585473125110
29.95447388876510	-28.40619821125670
29.95521479863610	-28.40651237871620
29.95581251468760	-28.40661926777250
29.95642493731230	-28.40661496866170
Pline  4
29.95588629185810	-28.36591087565610
29.95486714313270	-28.36920007631010
29.95407020134700	-28.37164047368990
29.95381863287230	-28.37260402110590
Pline  18
29.95946013804040	-28.36527843417480
29.95886809165890	-28.36586351814610
29.95834424438700	-28.36644654696300
29.95800630885070	-28.36682265458400
29.95759038735280	-28.36727009069640
29.95724084004630	-28.36764611869310
29.95697455568600	-28.36793257363900
29.95679694242540	-28.36812363861830
29.95614101746890	-28.36864169598870
29.95560391419150	-28.36901727455570
29.95516626773080	-28.36912586232030
29.95453114846690	-28.36930132506310
29.95390665656540	-28.36948950114380
29.95304880482830	-28.36981419786710
29.95246896357760	-28.36988907199650
29.95180510003340	-28.36982212508620
29.95100774366000	-28.36975742601870
Pline  6
29.12476628859820	-28.27807061006060
29.12480510594160	-28.27819041418410
29.12484669621600	-28.27831877624470
29.12492981285320	-28.27852047178270
29.12517882149610	-28.27883207254410
29.12678314661520	-28.28047533426220
Pline  14
28.58087062665140	-28.16269837916770
28.58107708705200	-28.16298637740100
28.58217056709700	-28.16498059154860
28.58262453450370	-28.16551456508010
28.58325062905670	-28.16593351129640
28.58389828080670	-28.16635240628750
28.58458889405150	-28.16671388145060
28.58573256029060	-28.16724629107390
28.58695152242550	-28.16772120040120
28.58803015273880	-28.16810088476720
28.58904390648340	-28.16839472859060
28.58961568282590	-28.16863225622640
28.59019879297620	-28.16907992943740
28.59101272641170	-28.16987350203940
Pline  12
28.59605881212900	-28.17219032878120
28.59651254394560	-28.17260006384220
28.59709197462500	-28.17281264042990
28.59791894652810	-28.17298359829700
28.59866875865470	-28.17291026951640
28.59920056918660	-28.17263275004420
28.59933556806550	-28.17241192435970
28.60000003744070	-28.17232436794210
28.60061800390460	-28.17240889526910
28.60115752347240	-28.17265600487680
28.60168650485250	-28.17298911770340
28.60185037288910	-28.17317975797910
Pline  5
28.60400239061700	-28.17403877450730
28.60515943201090	-28.17398393137320
28.60603260324480	-28.17406781361880
28.60683079103270	-28.17431427848050
28.60722617371920	-28.17456095854860
Pline  12
28.61198021188660	-28.17536850101250
28.61291387643880	-28.17600952742560
28.61364786861120	-28.17640896450960
28.61424151622120	-28.17672276242600
28.61592386175370	-28.17710074009850
28.61687228771210	-28.17710794009210
28.61761171443440	-28.17688293720800
28.61854971184800	-28.17682445509060
28.61910284632930	-28.17698773882500
28.61951293799340	-28.17717778013130
28.62014024915420	-28.17794047828920
28.62043319198540	-28.17834726017830
Pline  18
28.64433617580620	-28.19021051651410
28.64511774991000	-28.19017076409270
28.64566769879090	-28.19024571093070
28.64618561443910	-28.19041627588320
28.64659014895610	-28.19060433034640
28.64686584615940	-28.19078702155010
28.64734156009650	-28.19124429792320
28.64771033941850	-28.19196935724540
28.64802851697540	-28.19257220657610
28.64808082294770	-28.19322940070520
28.64838445421270	-28.19380178052880
28.64868754153490	-28.19420220017030
28.64957658090140	-28.19493025365620
28.65011348184630	-28.19517276650540
28.65121383702840	-28.19544681121120
28.65228980378780	-28.19544354703810
28.65297021774710	-28.19525093084740
28.65375329536070	-28.19495972700620
Pline  20
28.65838070574550	-28.19491129360770
28.65908199894890	-28.19524356394260
28.65981566840350	-28.19545168895340
28.66050572100400	-28.19550707789090
28.66138938895730	-28.19543772564490
28.66201391489090	-28.19523534917520
28.66288448267640	-28.19484539160430
28.66375377423120	-28.19475181578640
28.66461981741540	-28.19443506266680
28.66570766921630	-28.19418358936840
28.66659084342060	-28.19397091077870
28.66714028302790	-28.19388335813460
28.66777611391190	-28.19384333081300
28.66866807106590	-28.19392190606700
28.66946957257580	-28.19418240756520
28.66987988483980	-28.19439140654610
28.67048486821210	-28.19479091203270
28.67103630192320	-28.19527328227360
28.67206409974840	-28.19640088965280
28.67275433228880	-28.19719467903150
Pline  8
28.75200962199540	-28.19890646703120
28.75309484899770	-28.19881937501560
28.75428099499770	-28.19880073601560
28.75490631099770	-28.19889673201560
28.75622154399770	-28.19918452201570
28.75699762999770	-28.19947207901570
28.75759219504580	-28.19976578508370
28.75817029892640	-28.20001410362790
Pline  6
28.76779914900000	-28.20218927700000
28.76896448900000	-28.20211912900000
28.76976236700000	-28.20221510000000
28.77017202600000	-28.20234926200000
28.77099131600000	-28.20263674500000
28.77188714699120	-28.20311729506520
Pline  26
28.77245654699120	-28.20416907506600
28.77282264099130	-28.20482022106640
28.77323195299160	-28.20537564406680
28.77346899399160	-28.20560548706680
28.77398633499160	-28.20595031506720
28.77467627299160	-28.20621859106720
28.77506442599160	-28.20629529806730
28.77577608399160	-28.20637210306760
28.77625062599160	-28.20631483206750
28.77717820599160	-28.20610445306720
28.77944749728850	-28.20529231558090
28.78086726599160	-28.20478418106640
28.78470730899200	-28.20332982106540
28.78580754399200	-28.20290880106520
28.78630363599200	-28.20281315706520
28.78686438299200	-28.20281326406520
28.78742506999200	-28.20288994706520
28.78809343899200	-28.20319644306520
28.78983950899200	-28.20442224306600
28.79023490313980	-28.20470707523340
28.79063712899200	-28.20499682606640
28.79086302214400	-28.20510832124750
28.79092122525300	-28.20513704874090
28.79160733699200	-28.20547569206680
28.79233197999200	-28.20582688906720
Pline  9
28.79260688699600	-28.20615058403360
28.79283599232770	-28.20724495805370
28.79285199146190	-28.20732138073780
28.79287853199600	-28.20744815603400
28.79302920599600	-28.20792686603420
28.79330928799600	-28.20838647403440
28.79389121199610	-28.20903758503460
28.79490443199620	-28.20980365503480
28.79594643699620	-28.21051682503520
Pline  17
28.79609141743940	-28.21132309652780
28.79632941930890	-28.21209668888330
28.79649034411250	-28.21278120957030
28.79669037518150	-28.21321260409920
28.79718828299620	-28.21376760003620
28.79748807871080	-28.21399184698440
28.79759791499620	-28.21407400403640
28.79802919899620	-28.21422724903640
28.79861153699620	-28.21430391103640
28.79921548099620	-28.21428485803640
28.80031557199620	-28.21418924503640
28.80102735399620	-28.21420841903640
28.80169594599620	-28.21430422503640
28.80264498399620	-28.21434258603640
28.80314108899620	-28.21430437703640
28.80369762599620	-28.21424266803640
Pline  11
28.81728831399660	-28.21605275403700
28.81757751752300	-28.21612505903630
28.81895060199660	-28.21646834003720
28.82453714799660	-28.21662076503720
28.82453714499660	-28.21662125403720
28.82507637399660	-28.21665947603720
28.82663196115560	-28.21674526329180
28.82838827498820	-28.21684178167210
28.83133155399680	-28.21700346203730
28.83366110699680	-28.21704141703740
28.83424396799680	-28.21705924003740
Pline  8
28.83831887999700	-28.22089290603860
28.83924686799700	-28.22157848003880
28.84203710791790	-28.22460908741710
28.84322348443480	-28.22589759601680
28.84435841399700	-28.22713019004070
28.84770169599710	-28.23080569004200
28.84895281099720	-28.23220312704240
28.84963238999720	-28.23302557604260
Pline  14
28.87062754100000	-28.23844921500000
28.87132505300000	-28.23882027700000
28.87192915100000	-28.23899234700000
28.87259797700000	-28.23906863500000
28.87309423800000	-28.23903017300000
28.87361194700000	-28.23893420900000
28.87518683300000	-28.23835907000000
28.87883259700000	-28.23672984500000
28.88491580600000	-28.23396955900000
28.88780635700000	-28.23278088600000
28.88843192100000	-28.23258906200000
28.89091272100000	-28.23218558800000
28.89548598500000	-28.23139786400000
28.89703696541050	-28.23108043946540
