[gdal-dev] Help from MapInfo users, please
Zoltan Szecsei zoltans at geograph.co.za
Fri Nov 11 04:08:38 EST 2011
Koszonom nagyon szepen.
(and that's the limit of my written Hungarian - I was 3 years old when
we came to South Africa)
Big thanks,
Zoltan
On 2011/11/11 10:53, Luca Sigfrido Percich wrote:
> Hi Zoltan,
> tessek. (If i remember the little hungarian I used to know)
> Converted with MapInfo 7.5 Table|Import command
> All the best
> Sig
> Il giorno ven, 11/11/2011 alle 10.11 +0200, Zoltan Szecsei ha scritto:
>> Hi,
>> I am trying to get some ogr2ogr and mitab issues regarding NULL values
>> in MID&  TAB files, resolved.
>> My (no longer so trusty) MapInfo v4.52 doesn't seem to recognize the
>> dongle in Windows 7 (I have tried different Sentinal drivers, but no
>> luck).
>> The thread of the problem can be found at:
>> http://trac.osgeo.org/gdal/ticket/4337#comment:9
>> Please  can a MapInfo user convert the attached files to Mapinfo TAB
>> format and email it back to me, so that we can use it for test data.
>> Please do NOT use ogr2ogr or tab2tab - these are the products that
>> handle this data incorrectly !!!!
>> Please state the version of MapInfo you have used for the conversion
>> to TAB.
>> Big thanks&  kind regards,
>> Zoltan
>> Zoltan Szecsei PrGISc [PGP0031]
>> Geograph (Pty) Ltd.
>> P.O. Box 7, Muizenberg 7950, South Africa.
>> 65 Main Road, Muizenberg 7945
>> Western Cape, South Africa.
>> 34° 6'16.35"S 18°28'5.62"E
>> Tel: +27-21-7884897  Mobile: +27-83-6004028
>> Fax: +27-86-6115323     www.geograph.co.za
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> _____________
> PRIVACY
> Le informazioni contenute in questo messaggio sono riservate e confidenziali. Il loro utilizzo e' consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo dal Suo Sistema e a distruggere le varie copie o stampe, dandone gentilmente comunicazione all’indirizzo mail del mittente. Ogni utilizzo improprio e' contrario ai principi del D.lgs 196/03 e alla legislazione europea (Direttiva 2002/58/CE).
> PRIVACY
Geograph (Pty) Ltd.
