[gdal-dev] Re: can not debug gdal1.8.1 at visual studio 2008
Mateusz Łoskot mateusz at loskot.net
Wed Nov 16 10:14:48 EST 2011
On 16 November 2011 15:02, mrym <meryemvrl at gmail.com> wrote:
> Ok. i see this message too "gdal18.dll, Binary was not built with debug
> information." i've replaced /MD with /MDd in flags for debug and build gdal
> again, but i still cannot debug gdal functions.
1) Not build but rebuild GDAL with correct flags
OPTFLAGS=$(OPTFLAGS) /MDd /DDEBUG /D_DEBUG
2) Rebuild your program linking against GDAL
3) Check if you have symbols database generated (gdal18.pdb file size >20-30MB)
4) Check if GDAL links against Debug C/C++ Run-Tim
dumpbin /ALL python32_d.dll | find /i "msvcr"
5) Execute your program under debugger, try to step in GDALAllRegister()
6) Check if you step into your own program at all
> and i don't know what to do..:(
I'd start with writing clear posts, describing in details steps what you do:
IOW, http://catb.org/~esr/faqs/smart-questions.html#beprecise
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
Member of ACCU, http://accu.org
