[gdal-dev] Windows FWTools GDAL built with GEOS intersection support?
Even Rouault even.rouault at mines-paris.org
Wed Nov 16 13:43:14 EST 2011
> > Since FwTools is not maintained, I think the FwTools paragraph on the
> > page http://trac.osgeo.org/gdal/wiki/DownloadingGdalBinaries should be
> > removed, or at least put at the bottom of the page. Presently, it is
> > misleading.
> If a reader hangs on reading until the second paragraph, she will know
> clearly what is the status of FWTools and what is recommended option:
> "The latest FWtools version for Windows, 2.4.7, dates back to a pre-1.6
> GDAL version. In order to benefit from the latest and greatest, you can
> refer to the other
> binary builds mentionned in the here-after Windows section. "
But I know that people only read up to the point where they have a link to a
downloadable item ;-) I've moved the FWTools section at the bottom of the page
> Best regards,
