[gdal-dev] GMLJP2 question
Reynolds, Scott scott at agi.com
Thu Nov 17 17:47:12 EST 2011
I have a JP2 image whose extent is supposed to be from (0E deg , 0N deg)
to (10E deg, 10N deg) but gdalinfo (from FWTools 2.4.7) is reporting
extents that are off by 0.5 pixel north and west.  The GML identifies
the origin of the image as (0E deg, 10N deg).  My understanding is that
GDAL automatically adjusts to account for pixel center vs. pixel corner
format differences and always reports pixel corners.  What I'm not sure
of is whether GML thinks the origin is centered on the top left pixel or
at the top left corner of the top left pixel.
Can someone tell me whether I need to submit a bug against:
1)      GDAL
2)      JP2 writer
3)      Me
Thanks,
Scott
Driver: JP2ECW/ERMapper JPEG2000
Files: e:\TestData\junk.jp2
Size is 256, 256
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0,
        AUTHORITY["EPSG","8901"]],
    UNIT["degree",0.01745329251994328,
        AUTHORITY["EPSG","9122"]],
    AUTHORITY["EPSG","4326"],
    AXIS["Latitude",NORTH],
    AXIS["Longitude",EAST]]
GeoTransform =
  10.01953125, 0, -0.0390625
  -0.01953125, 0.0390625, 0
Corner Coordinates:
Upper Left  (  10.0195313,  -0.0195313) ( 10d 1'10.31"E,  0d 1'10.31"S)
Lower Left  (   0.0195313,  -0.0195313) (  0d 1'10.31"E,  0d 1'10.31"S)
Upper Right (  10.0195313,   9.9804688) ( 10d 1'10.31"E,  9d58'49.69"N)
Lower Right (   0.0195313,   9.9804688) (  0d 1'10.31"E,  9d58'49.69"N)
Center      (   5.0195313,   4.9804688) (  5d 1'10.31"E,  4d58'49.69"N)
Band 1 Block=256x1 Type=Byte, ColorInterp=Red
  Overviews: arbitrary
Band 2 Block=256x1 Type=Byte, ColorInterp=Green
Band 3 Block=256x1 Type=Byte, ColorInterp=Blue
Band 4 Block=256x1 Type=Byte, ColorInterp=Undefined
The GML embedded in the file is
<gml:FeatureCollection
xmlns:gml="http://www.opengis.net/gml"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/gml
http://www.math.ubc.ca/~burggraf/gml/gml4jp2.xsd">
<gml:boundedBy>
  <gml:Null>withheld</gml:Null>
</gml:boundedBy>
<gml:featureMember>
  <gml:RectifiedGridCoverage dimension="2" gml:id="RGC0001">
   <gml:rectifiedGridDomain>
    <gml:RectifiedGrid dimension="2">
     <gml:limits>
     <gml:GridEnvelope>
       <gml:low>0 0</gml:low>
       <gml:high>255 255</gml:high>
      </gml:GridEnvelope>
     </gml:limits>
     <gml:axisName>x</gml:axisName>
     <gml:axisName>y</gml:axisName>
     <gml:origin>
      <gml:Point gml:id="P0001" srsName="urn:ogc:def:crs:EPSG::4326">
       <gml:pos>0.0000000000000 10.0000000000000</gml:pos>
      </gml:Point>
     </gml:origin>
     <gml:offsetVector
srsName="urn:ogc:def:crs:EPSG::4326">0.0390625000000
-0.0000000000000</gml:offsetVector>
     <gml:offsetVector
srsName="urn:ogc:def:crs:EPSG::4326">-0.0000000000000
-0.0390625000000</gml:offsetVector>
    </gml:RectifiedGrid>
   </gml:rectifiedGridDomain>
  </gml:RectifiedGridCoverage>
</gml:featureMember>
</gml:FeatureCollection>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111117/de27551c/attachment-0001.html
