[gdal-dev] KMLSuperOverlay in Google Earth 6.1.0.5001
Roland Duhaime roland.duhaime at gmail.com
Fri Nov 18 09:13:48 EST 2011
Roger,
The PNG gdalinfo details are:
Driver: PNG/Portable Network Graphics
Files: 7.png
Size is 218, 218
Coordinate System is `'
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,  218.0)
Upper Right (  218.0,    0.0)
Lower Right (  218.0,  218.0)
Center      (  109.0,  109.0)
Band 1 Block=218x1 Type=Byte, ColorInterp=Red
  Mask Flags: PER_DATASET ALPHA
Band 2 Block=218x1 Type=Byte, ColorInterp=Green
Band 3 Block=218x1 Type=Byte, ColorInterp=Blue
Band 4 Block=218x1 Type=Byte, ColorInterp=Alpha
Thanks,
Roland
On Thu, Nov 17, 2011 at 5:21 PM, Roger André <randre at gmail.com> wrote:
> What is the output of gdalinfo on one of the PNG's in the superoverlay?
> On Thu, Nov 17, 2011 at 1:36 PM, Roland Duhaime <roland.duhaime at gmail.com>wrote:
>> Has anyone else experienced the latest version of Google Earth
>> (6.1.0.5001) or the G.E. API not loading PNG formatted KMLSUPEROVERLAYs
>> created using gdal_translate?  The same KMZ files worked in the past.
>> Thanks,
>> Roland
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111118/37cf58fa/attachment.html
