[gdal-dev] KMLSuperOverlay in Google Earth 6.1.0.5001
Roland Duhaime roland.duhaime at gmail.com
Fri Nov 18 11:59:08 EST 2011
Kyle,
Yes, I just removed the spaces after the commas in the <coordinates> tag
and was then able to open one of the kml files in G.E.  I suspect that
there are m(b)illions? of kmz files in cyberspace that won't meet the 2.2
standard because of this.  I am not sure of the most effective solution.
 In addition to documentation, perhaps we need a conversion tool for legacy
2.1 kml superoverlays.  Perhaps getting the 2.2 KML standard to lighten-up
a tad would be complicated.
Thanks Again,
Roland
On Fri, Nov 18, 2011 at 11:14 AM, Kyle Shannon <KShannon at gcs-research.com>wrote:
>  Possible issue with output (from
> http://earth.google.com/support/bin/answer.py?answer=40901):****
> *To conform more closely with the OGC KML 2.2 standard, we've made the
> parsing of the <coordinates> tag more strict in version 6.1. Spaces must
> only be used to separate the (longitude,latitude,altitude) triplets which
> specify the coordinates of a single point. It is invalid to add spaces
> between individual coordinates. We understand that previous versions of the
> client were more lenient, so if your KML files contain spaces beween
> coordinates in coordinate triplets, an easy workaround is to remove all
> whitespace located immediately before or after commas inside a
> <coordinates> tag.*
> I checked one file, and there were spaces after the commas:****
> <kml xmlns="http://earth.google.com/kml/2.1" xmlns:gx="
> http://www.google.com/kml/ext/2.2">****
>      <Document>****
>            <name>1/1/1.kml</name>****
>            <Style>****
>                 <ListStyle id="hideChildren">****
>                      <listItemType>checkHideChildren</listItemType>****
>                 </ListStyle>****
>            </Style>****
>            <Region>****
>                 <Lod>****
>                      <minLodPixels>128</minLodPixels>****
>                      <maxLodPixels>2048</maxLodPixels>****
>                 </Lod>****
>                 <LatLonAltBox>****
>                      <north>41.900791</north>****
>                      <south>41.890160</south>****
>                      <east>12.505676</east>****
>                      <west>12.492253</west>****
>                 </LatLonAltBox>****
>            </Region>****
>            <GroundOverlay>****
>                 <drawOrder>1</drawOrder>****
>                 <Icon>****
>                      <href>1.jpg</href>****
>                 </Icon>****
>                 <gx:LatLonQuad>****
>                      <coordinates>****
>                            12.492253, 41.890160, 0****
>                            12.506078, 41.890461, 0****
>                            12.505676, 41.900791, 0****
>                            12.491848, 41.900490, 0****
>                      </coordinates>****
>                 </gx:LatLonQuad>****
>            </GroundOverlay>****
> Seems like a quick fix.  Someone should probably file a ticket for
> documentation, I can do that if need be.****
> kss****
> *From:* gdal-dev-bounces at lists.osgeo.org [mailto:
> gdal-dev-bounces at lists.osgeo.org] *On Behalf Of *Roland Duhaime
> *Sent:* Friday, November 18, 2011 7:14 AM
> *To:* gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] KMLSuperOverlay in Google Earth 6.1.0.5001****
> Roger,****
> The PNG gdalinfo details are:****
> Driver: PNG/Portable Network Graphics****
> Files: 7.png****
> Size is 218, 218****
> Coordinate System is `'****
> Image Structure Metadata:****
>   INTERLEAVE=PIXEL****
> Corner Coordinates:****
> Upper Left  (    0.0,    0.0)****
> Lower Left  (    0.0,  218.0)****
> Upper Right (  218.0,    0.0)****
> Lower Right (  218.0,  218.0)****
> Center      (  109.0,  109.0)****
> Band 1 Block=218x1 Type=Byte, ColorInterp=Red****
>   Mask Flags: PER_DATASET ALPHA****
> Band 2 Block=218x1 Type=Byte, ColorInterp=Green****
> Band 3 Block=218x1 Type=Byte, ColorInterp=Blue****
> Band 4 Block=218x1 Type=Byte, ColorInterp=Alpha****
> Thanks,****
> Roland****
> On Thu, Nov 17, 2011 at 5:21 PM, Roger André <randre at gmail.com> wrote:****
> What is the output of gdalinfo on one of the PNG's in the superoverlay?***
> On Thu, Nov 17, 2011 at 1:36 PM, Roland Duhaime <roland.duhaime at gmail.com>
> wrote:****
> Has anyone else experienced the latest version of Google Earth
> (6.1.0.5001) or the G.E. API not loading PNG formatted KMLSUPEROVERLAYs
> created using gdal_translate?  The same KMZ files worked in the past.****
> Thanks,****
> Roland****
> gdal-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/gdal-dev****
> This email message is for the sole use of the intended recipient(s) and
> may contain confidential and privileged information. Any unauthorized
> review, use, disclosure or distribution is prohibited. If you are not the
> intended recipient, please contact the sender by reply email and delete the
> original message.   ­­
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111118/6a70f270/attachment-0001.html
