[gdal-dev] KMLSuperOverlay in Google Earth
Kyle Shannon KShannon at gcs-research.com
Fri Nov 18 14:12:27 EST 2011
Thanks Even, I have a patch, but I can't test it here.  It is probably faster and easier for you anyway.  Thanks again.
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: Friday, November 18, 2011 12:11 PM
To: gdal-dev at lists.osgeo.org
Cc: Kyle Shannon
Subject: Re: [gdal-dev] KMLSuperOverlay in Google Earth
Le vendredi 18 novembre 2011 20:04:13, Kyle Shannon a écrit :
> I doubt they will change the spec, and I am sure you are right about
> the many bad files.  I imagine that most people just checked the
> output from his or her program in google earth and said "Good enough".
> If no one gets around to it before I get off work and to a *nix
> workstation, I will file a ticket and a patch.  It is probably safe to backport to 1.8 as well.
I was just looking at this. I'll notify you of the ticket when done. Testing will be welcome because I have a much older GE version.
