[gdal-dev] Re: Problem joining a shapefile and MDB
Even Rouault even.rouault at mines-paris.org
Fri Nov 18 16:03:33 EST 2011
Le vendredi 18 novembre 2011 22:00:55, boesiii a écrit :
> Even,
> What is the correct procedure to upgrade a MS4W installation?  I downloaded
> release-1310-gdal-1-8-1-mapserver-6-0-1.zip and I copied OGRINFO.EXE to the
> current location.  After I did this OGRINFO still crashed.  Do I need to
> copy other files?
I'm not sure you can mix stuff like that. You should ask for confirmation from
the MS4W packagers, but perhaps they have already an updated version of MS4W
with GDAL 1.8.1
> Thanks,
> Ed
> http://osgeo-org.1803224.n2.nabble.com/Problem-joining-a-shapefile-and-MDB
> -tp7009404p7009680.html Sent from the GDAL - Dev mailing list archive at
> Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
