[gdal-dev] VSI issue
Ari Jolma ari.jolma at gmail.com
Sat Nov 19 09:12:51 EST 2011
On 11/19/2011 11:40 AM, Ari Jolma wrote:
> On 11/18/2011 09:02 PM, Even Rouault wrote:
>> Le vendredi 18 novembre 2011 15:04:55, Ari Jolma a écrit :
>>> Hi,
>>> A few days ago on this list I mentioned that the following works
>>> using a
>>> recent version from trunk (and Perl bindings):
>>> use Geo::GDAL;
>>> $datasource = Geo::OGR::Open('/home/ajolma/data/parks.shp');
>>> Geo::OGR::Driver('GML')->Copy($datasource, '/dev/stdout');
>>> I'm testing a simple WFS written in Perl and basically the above is the
>>> contents of the GetFeature subroutine (the datasource name comes of
>>> course from a configuration file). However, using this in a Perl CGI
>>> program leads to "RuntimeError Failed to create GML file
>>> /dev/stdout." -
>>> it seems like the VSI does not work when the Perl program is run as a
>>> CGI program. I may investigate the issue more but maybe somebody has an
>>> answer right away. - I can forward the output to a file and then send
>>> the file but it would be nice to feed it directly to the client.
>> The most obvious idea I have is that something closes the stdout of
>> the forked
>> CGI ?
> The standard way to send text (HTML, XML, ..) to the client in a Perl
> CGI process is to print to stdout (exactly the same way as one does in
> a command line Perl program). Thus it seems that the VSI stdout is
> somehow not a standard stdout - I'll take a deeper look into what goes
> on.
I found the problem. It is changeset 23022 (by you, Even :), which
removes support for "stdout" and adds "/dev/stdout" as an alias to
"/vsistdout/". Simple, but took me a while to find out especially as the
log message begins "mentions in the doc".
> Another thing is that in mod_perl sending to client is through a
> handle (use the print method of an object) - it would be nice to be
> able to give that handle to the GDAL copy method.
mod_perl is probably not a problem. However, Perl supports memory files
too and it would be interesting to be able to use VSI memory files and
Perl memory files interchangeably.
Ari
> Ari
>>> Regards,
>>> Ari
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
