[gdal-dev] Making a "hole" in existing image
Jay Jennings Jennings.Jay at geoeye.com
Tue Nov 22 15:01:23 EST 2011
Thanks, that suggestion worked great.  For simplicity, I used KML instead of shapefile, as follows:
gdal_rasterize -burn 0 -b 1 -b 2 -b 3 -l TestLayerName HoleExtent.kml OriginalRGB.tif
And my KML file looks like this, with 'coordinates' in longitude/latitude:
<?xml version="1.0" encoding="utf-8" ?>
<kml xmlns="http://www.opengis.net/kml/2.2">
<Document><Folder><name>TestLayerName</name>
  <Placemark>
     <Style><LineStyle><color>ff0000ff</color></LineStyle><PolyStyle><fill>0</fill></PolyStyle></Style>
     <Polygon>
       <outerBoundaryIs>
        <LinearRing>
         <coordinates>-101.00,30.00 -100.00,30.00 -100.00,29.50 -101.00,29.50 -101.00,30.00</coordinates>
        </LinearRing>
       </outerBoundaryIs>
     </Polygon>
  </Placemark>
</Folder></Document>
</kml>
-----Original Message-----
From: Travis Kirstine [mailto:traviskirstine at gmail.com]
Sent: Tuesday, November 22, 2011 1:16 PM
To: Jay Jennings
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Making a "hole" in existing image
gdal_rasterize can be used to create a hole using a polygon from a
vector datasource.
gdal_rasterize -burn 0 -b 1 -b 2 -b 3 -l my_polygon my_polygon.shp my_image.tif
regards
On 22 November 2011 11:22, Jay Jennings <Jennings.Jay at geoeye.com> wrote:
> Hi List,
> I'm looking for a slick way, using GDAL utilities, to make a NoData "hole"
> in an existing image :  I'd like to set value 0 (which is this image's
> NoData value) for each band of the image within the rectangle denoted by
> minX, minY, maxX, maxY.  I looked at 'gdal_translate' and 'gdalwarp' but I
> didn't see any obvious way to get there.
> Jay Jennings
> Senior Software Developer
> GeoEye, Inc. (NASDAQ: GEOY)
> gdal-dev mailing list
