[gdal-dev] esri hdr format header
Travis Kirstine traviskirstine at gmail.com
Wed Nov 23 10:01:40 EST 2011
Francesco
Information regarding the format can be found under the EHdr -- ESRI
.hdr Labelled section in
http://www.gdal.org/frmt_various.html
We have had issues inhouse dealing with hdr files - you must add the
nbits / pixeltype to the correctly read the files with GDAL.  The only
solution that we have found to deal with GDAL created hdr files is to
parse out values that are causing problems.
It is my recollection that most GIS applications can read hdr files
created by GDAL including most versions of ArcGIS
On 23 November 2011 08:00, francesco <francesco.pirotti at unipd.it> wrote:
> Hello,
> I looked all day for information regarding the following problem, but found
> none, so maybe the list can give me a hand:
> When using GDAL C API reading and writing ESRI hdr files (floating point
> binaries), the output header is very different from the header of the input
> file (see examples below).
> From GDAL documentation ESRI files should be written using the first header
> example.  Am I missing some very obvious thing here? -Problem is that some
> GIS programs do not recognize the header in output from GDAL.
> Thank you for you time!
> Cheers,
> Francesco Pirotti
> Header in INPUT:
> ncols         2000
> nrows         2000
> xllcorner     424000
> yllcorner     4550000
> cellsize      1
> NODATA_value  -9999
> byteorder     LSBFIRST
> NODATA         -9999
> Header in OUTPUT:
> BYTEORDER      I
> LAYOUT         BIL
> NROWS          2000
> NCOLS          2000
> NBANDS         1
> NBITS          32
> BANDROWBYTES   8000
> TOTALROWBYTES  8000
> PIXELTYPE      FLOAT
> ULXMAP         424000.5
> ULYMAP         4551999.5
> XDIM           1
> YDIM           1
> NODATA         -9999
> Francesco Pirotti
> Dep. TESAF
> CIRGEO – Interdepartmental Research Center on Cartography Photogrammetry
> Remote Sensing and G.I.S.
> University of Padova
> Web: http://www.cirgeo.unipd.it/cirgeo/francescopirotti.htm
> Email: francesco.pirotti at unipd.it
> Work Phone: +39 049 827 2710
> Work Cell.: +39 392 395 2067
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
