[gdal-dev] Getting data values from a first GeoTIFF and do some map algebra type operations with a second GeoTIFF
Joaquim Luis jluis at ualg.pt
Wed Nov 23 15:48:04 EST 2011
Derek,
These are the type of operations that I recommend GMT (built with GDAL
off course). With GMT5 ii as simple as
grd2xyz yourGeotiff > outfile
this saves  x,y,z triplets. Add -ZTLa to write only the z values (many
other options available)
Joaquim
> Hello,
> I am new to GDAL and raster programming in general and hoping that I
> can get some guidance. I have GeoTIFF which are projected in WGS84 and
> a single band.I am trying to start simply with the concept of getting
> out the data values from the GeoTIFF from one file so that I compare
> them to another.However, I am a bit stuck at the point of getting out
> operations with a second GeoTIFF.Here is what I have so far:
> from osgeo import gdal, gdalconst
> import os, sys, time
> import numpy
> ds = gdal.Open('C:\\Data\\GIS\\python\\gdal\\CMIP3-tb1_2021_2050.tif',
> gdal.GA_ReadOnly)
> cols = ds.RasterXSize
> rows = ds.RasterYSize
> bands = ds.RasterCount
> print cols, rows, bands
> gdal.AllRegister()
> gt = ds.GetGeoTransform()
> print gt
> xOrigin = gt[0]
> yOrigin = gt[3]
> pixWidth = gt[1]
> print "pixWidth " + str(pixWidth)
> pixHeight = gt[5]
> print "pixHeight " + str(pixHeight)
> for r in range(rows):
> data = ds.GetRasterBand(1).ReadAsArray(0, r, cols, 1)
> print str(data)
> Is this the correct way to be going about this?Any guidance or best
> practices/algorithms would be greatly appreciated.
> Thanks,
> Derek
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111123/3ce45d4e/attachment-0001.html
