[gdal-dev] Anyone against making OGR SQL 'SUBSTR' conformant with other SQL implementations ?
Howard Butler hobu.inc at gmail.com
Thu Nov 24 16:50:36 EST 2011
On Nov 24, 2011, at 3:47 PM, Even Rouault <even.rouault at mines-paris.org> wrote:
> Hi,
> The implementation of the OGR SQL SUBSTR(string, offset[, length]) function
> considers that the character offset is like the convention of the C language,
> that is to say that the first character is offset 0, the second one is offset 1,
> etc... All other SQL implementations I've found consider 1 as the first
> character, 2 as the second one.
> For details and patch, see http://trac.osgeo.org/gdal/ticket/4348
> The only reason I'm reporting publicly here is that fixing that could break
> existing applications/scripts. The risk seems limited however because this
> function was introduced in 1.8.0 and happens not to be documented in
> http://gdal.org/ogr/ogr_sql.html
> So I think I'll apply the fix in trunk, and likely in 1.8 branch too. With a
> notice in the backward compatibility section of the NEWS file.
+1 to fixing it to be conformant.
Howard
