[gdal-dev] wms driver and support for more parameters in the URL - bug in curl?
Jachym Cepicky jachym.cepicky at gmail.com
Sat Nov 26 18:15:08 EST 2011
That was it!
Thanks a lot!
Jachym
2011/11/21 Even Rouault <even.rouault at mines-paris.org>:
>> I try
>> gdalwarp in.wms in.tiff
>> On my localhost, correst request with all 3 parameters arrives:
>> /cgi-bin/owsproxy.cgi?FROMCRS=epsg%3A4326&OWSSERVICE=WMS&OWSURL=http%3A%2F%
>> 2Fgeoportal2.uhul.cz%2Fwms_oprl&request=GetMap&version=1.1.1&layers=Lesni_t
>> yp&styles=default&srs=EPSG:3035&transparent=TRUE&format=image/png&width=936
>> &height=660&bbox=4559666.00000000,2941837.66667000,4566270.00000000,2946494
>> .33333000
>> But the our server or on other computer with *same* version of GDAL as
>> on my localhost, only the *first* one arrives:
>>  /cgi-bin/owsproxy.cgi?FROMCRS=epsg%3A4326&service=WMS&request=GetMap&versi
>> on=1.1.1&layers=Lesni_typ&styles=default&srs=EPSG:3035&transparent=TRUE&for
>> mat=image/png&width=936&height=660&bbox=4559666.00000000,2941837.66667000,4
>> 566270.00000000,2946494.33333000
>> So, is there some strange bug in GDAL? In some dependence library
>> (like curl?) Any other way, how to pass more aditional parameters to
>> the server with GDAL as client?
> I don't understand the different of behaviour you observe, but the cause of
> your issue is that the URL you put inside <ServerUrl> is not proper XML
> content. You should replace the & characters by &amp;
>> Thanks
>> Jachym
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
