[gdal-dev] Freischaltung Widemann Systeme Hamburg
Jan Tappenbeck tappenbeck at widemann.de
Mon Nov 28 06:07:12 EST 2011
  Am 26.11.2011 04:27, schrieb Hermann Peifer:
> Another option would be to gdal_translate to a .vrt by using
> -a_srs srs_def EPSG:31466
> -a_nodata value # in case you happen to know
> -a_ullr ulx uly lrx lry # coordinates at pixel edges, not their centre
> points
> Think about the .vrt as being the big brother of a world file. You
> might want to spend some time reading the documentation at [1], [2]
> and [3].
> [1] http://www.gdal.org/gdal_translate.html
> [2] http://www.gdal.org/gdal_vrttut.html
> [3] http://www.gdal.org/frmt_various.html#WLD
> Hermann
> On 25/11/2011 11:49, Jan Tappenbeck wrote:
>> HI !
>> i try my translation in use of an other tif-source files!
>> here even in the tif-header are informations about the reference - worst
>> coordintes:
>> C:\Program Files (x86)\FWTools2.4.7>gdalinfo
>> "D:\City\raster\gas\500\g8746-1_
>> cit.tif"
>> Driver: GTiff/GeoTIFF
>> Files: D:\City\raster\gas\500\g8746-1_cit.tif
>> Size is 16215, 8904
>> Coordinate System is `'
>> Origin = (-948545665.889520530000000,-1021132473.110479500000000)
>> Pixel Size = (3209.779041131308100,-3209.779041131308100)
>> Image Structure Metadata:
>> COMPRESSION=LZW
>> INTERLEAVE=BAND
>> Corner Coordinates:
>> Upper Left (-948545665.890,-1021132473.110)
>> Lower Left (-948545665.890,-1049712345.693)
>> Upper Right (-896499098.738,-1021132473.110)
>> Lower Right (-896499098.738,-1049712345.693)
>> Center (-922522382.314,-1035422409.402)
>> Band 1 Block=16215x1 Type=Byte, ColorInterp=Palette
>> Color Table (RGB with 256 entries)
>> 0: 255,255,255,255
>> i create following twf-file manuell:
>> 0.032098
>> 0.000000
>> 0.000000
>> -0.032098
>> 2586989.395890
>> 5746263.495720
>> but when i now try to translate by
>> C:\Program Files (x86)\FWTools2.4.7>gdalwarp -s_srs EPSG:31466 -t_srs
>> EPSG:25832 "D:\City\raster\gas\500\g8746-1_cit.tif"
>> "D:\City\raster\gas\500\g8746-1_cit_epsg_utm.tif"
>> i get following message:
>> Copying color table from D:\City\raster\gas\500\g8746-1_cit.tif to new
>> file.
>> Creating output file that is 0P x 0L.
>> ERROR 1: Attempt to create 0x0 dataset is illegal,sizes must be larger
>> than zero
>> did anyone / you have a idea how to translate successfully?
>> alternative to edit the coordinates manuell in the tif-file?
>> it is very important for me.
>> reagrads Jan :-)
Moin aus Hamburg,
ich möchte Sie bitten nachfolgendes Produkt freizuschalten:
[__] Widemann Systeme intern
[__] für nachfolgenden Kunden:
Produkt:
Seriennummer:
MAC-Adresse:
Server-Name:
Seats: [ ___]
Für eventuelle Rückfragen stehe ich Ihnen gerne zur Verfügung.
Freundliche Grüße
i.A. Jan Tappenbeck
Dipl. Vermessungsingenieur
CAD-Systemberater&  AutoCAD-Support
Widemann Systeme GmbH
CAD- und GIS-Systemhaus
Wiesbaden · Hamburg · München · Düsseldorf
Ackermannstraße 21, 22087 Hamburg
Fon: 040 / 229477-22
Fax: 040 / 229477-29
tappenbeck at widemann.de    www.widemann.de
Sitz der Gesellschaft: Wiesbaden, Amtsgericht Wiesbaden HRB 23345
Zu jedem Produkt das passende Forum unter http://www.widemann.de/wisysforen/
Widemann Systeme - aktuell:
geosi.DE - Vermessungssoftware ...
... für Straßenbau, Bauwesen, ....
- weitere Infos unter:
http://www.widemann.de/produkte/geoside/geosi.htm
Diese E-Mail enthält vertrauliche oder rechtlich geschützte Informationen.
Wenn Sie nicht der beabsichtigte Empfänger sind, informieren Sie bitte
sofort den Absender und löschen Sie diese E-Mail. Das unbefugte Kopieren
dieser E-Mail oder die unbefugte Weitergabe der enthaltenen Informationen
ist nicht gestattet.
The information contained in this message is confidential or protected by
law. If you are not the intended recipient, please contact the sender and
delete this message. Any unauthorised copying of this message or unauthorised
distribution of the information contained herein is prohibited.
