[gdal-dev] Anyone against making OGR SQL 'SUBSTR' conformant with other SQL implementations ?
Even Rouault even.rouault at mines-paris.org
Mon Nov 28 15:29:37 EST 2011
Le jeudi 24 novembre 2011 22:47:04, Even Rouault a écrit :
> Hi,
> The implementation of the OGR SQL SUBSTR(string, offset[, length]) function
> considers that the character offset is like the convention of the C
> language, that is to say that the first character is offset 0, the second
> one is offset 1, etc... All other SQL implementations I've found consider
> 1 as the first character, 2 as the second one.
> For details and patch, see http://trac.osgeo.org/gdal/ticket/4348
> The only reason I'm reporting publicly here is that fixing that could break
> existing applications/scripts. The risk seems limited however because this
> function was introduced in 1.8.0 and happens not to be documented in
> http://gdal.org/ogr/ogr_sql.html
> So I think I'll apply the fix in trunk, and likely in 1.8 branch too. With
> a notice in the backward compatibility section of the NEWS file.
Committed in trunk and 1.8 branch.
> Even
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
