[gdal-dev] Covert MODIS Land Temperatures Sinusoidal to Lat Lon
Etienne Tourigny etourigny.dev at gmail.com
Wed Nov 30 11:02:38 EST 2011
Thant works for me too.
A related question, does anyone know of an EPSG code to match this
sinusoidal projection used by MODIS?
Etienne
On Wed, Nov 30, 2011 at 1:26 PM, Vincent Schut <schut at sarvision.nl> wrote:
> On 11/30/2011 03:41 PM, elliott wrote:
>> Hello,
>> I have been searching for a way to convert the MODIS Land Temperature data
>> that is in a sinusoidal projection into WSG84 lat/lon but have not found any
>> definitive answers.
>> Any help would be greatly appreciated.
> I've been using this gdalwarp line, though for modis land spectral data and
> not temperature:
> gdalwarp -s_srs '+proj=sinu +R=6371007.181 +nadgrids=@null +wktext' -t_srs
> EPSG:4326 -srcnodata 0 -dstnodata 0 -r cubic -co "TILED=YES" -co "TFW=YES"
>  ${INFILE} ${OUTFILE}
> nb it's from a bash script so change the INFILE and OUTFILE stuff, and if
> you want to you can remove the -co tiled and tfw creation options.
> ymmv.
> Vincent.
>> Thanks!
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
