[gdal-dev] sandbox access for non-commiters
Mateusz Loskot mateusz at loskot.net
Thu Oct 6 17:03:48 EDT 2011
On 06/10/11 21:52, Antonio Valentino wrote:
> Il 06/10/2011 22:01, Etienne Tourigny ha scritto:
>> Thanks for the information.  It seems that using git-svn is more
>> suited for working locally, and then commiting back to the svn repos,
>> or as an easy way to stay in-sync with the main repos (like you do).
> IMHO the trick is using a separate branch for developing new features in
> order to be able to use git freely.
> When the job is done one should just rebase (locally) on the branch in
> sync with svn and use git-svn to push hanges back into svn.
> The weak point in the workflow is the initial cloning of the svn repo.
Indeed, because every developer aiming in the git svn workflow
has to do this initial step on his own. AFAIK, there is no way to
centralise it.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
Member of ACCU, http://accu.org
