[gdal-dev] Re: KML's extendedData not visible
jarmstrong joss.armstrong at gmail.com
Tue Oct 11 06:21:04 EDT 2011
I have a similar question regarding KML and OGR.
When trying to import the example extended data as given at
http://code.google.com/apis/kml/documentation/extendeddata.html
The extended data is not present in the created tables in the PG database
when imported from KML file using ogr2ogr command.
The database is created according to the template_postgis and the geometry
data is imported correctly.
Please let me know if this extended data should be present in the database
tables and if so what is required to do this.
Thanks
J Armstrong
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-dev-KML-s-extendedData-not-visible-tp5454623p6880389.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
