[gdal-dev] gdal_fillnodata.py filling interior holes in RGB images
Travis Kirstine traviskirstine at gmail.com
Wed Oct 12 13:20:48 EDT 2011
Thanks Brian,
I'll give it a try.
Regards
On 12 October 2011 13:00, Brian Case <rush at winkey.org> wrote:
> Travis,
> you have to run gdal_fillnodata on each band, then splice the outputs
> back together.
> if the nodata areas on the inside do not connect to the outside area you
> could create an alpha band
> ### -color 0,0,0 assumes odata value of 0
> nearblack -dstalpha -near 0 -nb 0 -setalpha -color 0,0,0 \
>          myfile.tif -o mytmpfile.tif
> gdal_translate -b 4 -of VRT mytmpfile.tif a.vrt
> gdal_fillnodata.py -md 1 -b 1 myfile.tif r_filled.tif
> gdal_fillnodata.py -md 1 -b 2 myfile.tif g_filled.tif
> gdal_fillnodata.py -md 1 -b 3 myfile.tif b_filled.tif
> gdalbuildvrt -resolution highest -separate filled.vrt \
>             r_filled.tif g_filled.tif b_filled.tif a.vrt
> if you want an rgba image use
> gdal_translate filled.vrt filled.tif
> otherwise for rgb with nodata use
> ### INIT_DEST=0 assumes nodata value of 0
> gdalwarp -wo INIT_DEST=0 filled.vrt filled.tif
> if your interior nodata areas connect to the outside nodata areas. I
> don't know howto deal with that other than to just live with the extra
> pixel around the outside of the valid data.
> Brian
> On Wed, 2011-10-12 at 08:46 -0400, Travis Kirstine wrote:
>> I have some RGB orthophotos that have interior holes, typically 1
>> pixel.  Most of the images have "valid" nodata around the edges.  I
>> would like to fill the interior holes while maintaining the valid
>> nodata around the edges.  I have tried gdal_fillnodata.py but cannot
>> get the utility to return a multiband image and / or interpolate only
>> interior holes.
>> Any help would be much appreciated
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
