[gdal-dev] PostgreSQL problems
David J. Bakeman dbakeman at comcast.net
Fri Oct 14 15:04:12 EDT 2011
Sorry I was trying to limit the bandwidth I used I figured it was
probably something really stupid and someone would just say you forgot
to XX :<;
Anyway this is a test database so it really is named mydb and I copied
the ogrinfo command from the PostgreSQL driver page for OGR.  I checked
before I started to confirm that the version of gdal I'm using supports
Postgresql and the ogrinfo --formats prints -> "PostgreSQL" (read/write)
so I believe that confirms it.
so both ogrinfo -ro PG:'dbname=mydb' and ogrinfo -ro PG:"dbname='mydb'"
and ogrinfo -ro PG:"dbname='mydb' user='dbakeman' port='5432'" return
the same failure which is to print FAILURE: and a list of drivers which
again includes postgresql.  I skipped the password part because I'm on a
system where I'm happy to run the ident authentication locally at least.
Here's what happens if I do psql -d mydb
\d
                List of relations
  Schema |       Name        | Type  |  Owner
  public | geography_columns | view  | dbakeman
  public | geometry_columns  | table | dbakeman
  public | products_swordxml | table | dbakeman
  public | pxml_points       | view  | dbakeman
  public | spatial_ref_sys   | table | dbakeman
  public | sword_trap        | table | dbakeman
Which is a list of the tables I've created.
Eli Adam wrote:
> David,
>       It probably is a configuration or simple error, however, you've
> not given much detail to let other people try to guess what it might
> be.  Kyle asked for the output of your command.  Also, the exact
> command (copied from terminal) may help too.  I looked at the OGR
> PosrgreSQL/PostGIS format page and copied this:
> PG:"dbname='databasename' host='addr' port='5432' user='x' password='y'"
> Could you try
> ogrinfo PG:"dbname='mydb' host='localhost' port='5432' user='x' password='y'"
> from the host machine?
> What do you get?
> PostgreSQL requires very complex quoting if you have any CAPs, do you
> have any caps in the db name, table, name, fieldname, etc?  With lack
> of information, I'm making random guesses that may not be relevant.
> I'm sure that if you provide detailed information, someone
> knowledgeable will quickly help you (or at least that is what I often
> observe on this list).
> Bests, Eli
> On Thu, Oct 13, 2011 at 5:10 PM, David J. Bakeman<dbakeman at comcast.net>  wrote:
>> Mateusz Łoskot wrote:
>>> On 13 October 2011 23:47, David J. Bakeman<dbakeman at comcast.net>    wrote:
>>>> I'm on Fedora core 14 with gdal 1.7.3.
>>>> I setup postgre and created a spatial enabled database with a table that
>>>> includes geometry.  I can connect using psql mydb.  However when I try
>>>> ogrinfo -ro PG:dbname=mydb it fails saying no driver found.
>>> ogrinfo --formats | grep -i post
>> I really think it's some configuration thing but I don't know what it is?
>>> and see if your GDAL/OGR installation has built-in PostgreSQL support.
>>> Best regards,
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
