[gdal-dev] proposal for a new GDAL/OGR utility app: gdalsrsinfo
Etienne Tourigny etourigny.dev at gmail.com
Mon Oct 17 02:58:48 EDT 2011
I've committed a slightly modified version to trunk.
I'll also add sometime soon a -srsformat option to gdalinfo with
similar behaviour.
I'll wait a bit before adding to the 1.8 branch
	M	gdal/apps/GNUmakefile
	M	gdal/apps/gdal_utilities.dox
	A	gdal/apps/gdalsrsinfo.c
On Sun, Oct 16, 2011 at 11:06 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> On Sun, Oct 16, 2011 at 6:02 PM, Etienne Tourigny
> <etourigny.dev at gmail.com> wrote:
>> I'll look into testepsg, I thought it was only for EPSG codes (guess I
>> was wrong). I also overlooked it because it is not in the GDAL
>> utilities page.
> Etienne,
> The most accurate part of the utilities name is "test".  It is not
> in the utilities page because it is not a supported utility.  It
> was really just for me to do testing.
>> Perhaps I can combine testepsg with gdalsrsinfo ?
> I would imagine gdalsrsinfo superceding testepsg.
> The gdaltransform utility already does the transformation work
> done by testepsg.
> I'm ok with you adding gdalsrsinfo as a supported utility.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Software Developer
