[gdal-dev] ArcSDE -> GeoTiff: Bit size calculation failed...
Wouter Schaubroeck wouter.schaubroeck at gmail.com
Mon Oct 17 05:06:42 EDT 2011
Howard,
Thanks for the information. As soon as I have a ArcMAP installation,
I'll check this (should be a matter of days).
Wouter
Wouter
http://blog.giswhat.be
On 14 October 2011 18:04, Howard Butler <hobu.inc at gmail.com> wrote:
>> SDE's length:16834 With bitmap length: 18529 Without bitmap length: 16834
> Wouter,
> I was the author of that code, but it has been a number of years since I've done anything with SDE. I believe it has to do with the fact that the raster layer you're reading from has a bitmask (bitmap) on it, and the SDE driver doesn't handle them.  The code probably needs to be updated to either disregard the mask, or handle it as a GDAL MaskBand.
> Hope this helps,
> Howard
