[gdal-dev] JPIPKAK dataset usage
    Garrett Potts
    potts at cfl.rr.com
    Mon Oct 17 07:33:55 EDT 2011
Hello Frank:
The GDALReadBlock works great in the 1.8.1 tag.
Thank you for the help!
Take care all
Garrett
On Oct 17, 2011, at 6:16 AM, Garrett Potts wrote:
> Hello Frank:
> Thank you for the information.  Yes, full resolution seems to work fine and also I was using the 1.8.0 zipped download.  Let me try the 1.8.1 and see if that will fix any problems.
> Thank you for the response and I will post my result.
> Take care
> Garrett
> On Oct 17, 2011, at 1:49 AM, Frank Warmerdam wrote:
>> On 11-10-16 06:38 PM, Garrett Potts wrote:
>>> The driver gets data but it is in the wrong resolution which means I am not
>>> calling these with the proper request.  I have traced the code but something
>>> doesn't quite make sense to me.  It appears the R-Level is computed based on
>>> the input request versus the output width height buffer ratio.  I think
>>> everything would get cleared up if I could see some example calls using
>>> above methods in when using the JPIPKAK dataset driver.
>> Garrett,
>> Do you get the right results at full resolution?   I would not be
>> entirely suprised to find that JPIP support for reading from band
>> overview objects is broken.  Also, are you using quite recent code?
>> There were some bugs in this at one point that got fixed.  GDAL 1.8.1
>> or trunk should be fine.
>> Best regards,
>> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>> light and sound - activate the windows | http://pobox.com/warmerda
>> and watch the world go round - Rush    | Geospatial Software Developer
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
