[gdal-dev] Confused about coordinate transformations
dev4cx4m9z at snkmail.com dev4cx4m9z at snkmail.com
Tue Oct 18 06:13:40 EDT 2011
My program does MANY other things that GDAL can’t. I’m using GDAL as a small part of something much larger. I need to do the transformation at runtime.
Marc,
proj4 usually comes with the gdal library. Instead of coding your own program, first try the ogr2ogr utility[1] that comes with the gdal library.
[1]: http://www.gdal.org/ogr2ogr.html
On Tue, Oct 18, 2011 at 1:36 PM, <dev4cx4m9z at snkmail.com> wrote:
I have a GIS database with all coordinates stored in WGS84 datum. I am trying to translate the coordinates of the database to the datum of my map. I am creating two OGRSpatialReference, one for WGS84 and one for the current map. I am then creating an OGRCoordinateTransformation. When I do so I get a PROJ.4 error – “No PROJ.4 translation for destination SRS, coordinate transformation initialisation has failed”
Question – Do I HAVE to use PROJ.4 to do the translation? Can I not just load the SRS with a WKT? I wish to avoid PROJ.4 as I’m unsure how to build it.
_______________________________________
Marc Hillman, Melbourne, Australia
http://users.tpg.com.au/users/mhillman/
marc .hillman @ t p g . c o m . a u
Eagles may soar, but weasels don't get sucked into jet engines.
Early bird gets the worm, but the second mouse gets the cheese.
If Barbie is so popular, why do you have to buy her friends?
All those who believe in psychokinesis, raise my hand..
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.1831 / Virus Database: 2092/4558 - Release Date: 10/17/11
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111018/b9c20f0d/attachment.html
