[gdal-dev] Confused about coordinate transformations
Etienne Tourigny etourigny.dev at gmail.com
Tue Oct 18 09:32:46 EDT 2011
Marc, if you get the same error with ogr2ogr/gdal_translate/gdalwarp,
it means that your destination srs is not supported.  What is the
definition that you use for the destination srs?
On Tue, Oct 18, 2011 at 8:13 AM,  <dev4cx4m9z at snkmail.com> wrote:
> My program does MANY other things that GDAL can’t. I’m using GDAL as a small
> part of something much larger. I need to do the transformation at runtime.
> Marc,
> proj4 usually comes with the gdal library. Instead of coding your own
> program, first try the ogr2ogr utility[1] that comes with the gdal library.
> [1]: http://www.gdal.org/ogr2ogr.html
> On Tue, Oct 18, 2011 at 1:36 PM, <dev4cx4m9z at snkmail.com> wrote:
> I have a GIS database with all coordinates stored in WGS84 datum. I am
> trying to translate the coordinates of the database to the datum of my map.
> I am creating two OGRSpatialReference, one for WGS84 and one for the current
> map. I am then creating an OGRCoordinateTransformation. When I do so I get a
> PROJ.4 error – “No PROJ.4 translation for destination SRS, coordinate
> transformation initialisation has failed”
> Question – Do I HAVE to use PROJ.4 to do the translation? Can I not just
> load the SRS with a WKT? I wish to avoid PROJ.4 as I’m unsure how to build
> it.
> _______________________________________
> Marc Hillman, Melbourne, Australia
> http://users.tpg.com.au/users/mhillman/
> marc .hillman @ t p g . c o m . a u
> Eagles may soar, but weasels don't get sucked into jet engines.
> Early bird gets the worm, but the second mouse gets the cheese.
> If Barbie is so popular, why do you have to buy her friends?
> All those who believe in psychokinesis, raise my hand..
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 2012.0.1831 / Virus Database: 2092/4558 - Release Date: 10/17/11
