[gdal-dev] proposed changes to netcdf export behaviour (perhaps RFC)
Tue Oct 18 17:22:13 EDT 2011
On Tue, Oct 18, 2011 at 1:10 PM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> 2) Change to a default south-up orientation for NetCDF data
Etienne,
Could you expand on this a bit?  In particular I'm wondering if:
1) Is a south-up file represented as south up to GDAL applications?
That is, will geotransform[5] be negative or positive?
2) Depending on the answer to the above, are there any performance
implications when gdal_translate'ing from and to north north up datasets
in other formats?
The changes to the driver seem major enough and with backward
compatibility issues such that I think an RFC is reasonable.  Calling
for a vote on the existing document will likely be sufficient after
any discussion here.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
and watch the world go round - Rush    | Geospatial Software Developer
