[gdal-dev] Autoconf macro for gdal-config
canduc17 candini at meeo.it
Wed Oct 19 03:44:56 EDT 2011
Compiling my gdal programs with the autotools, I would like to use
gdal-config in my configure.ac file, in order to manage gdal path on
different systems.
The same things is made for example with the PKG_CHECK_MODULES macro for
libraries which support pkg-config.
Is there a pre built macro to do the same thing?
Or should I write a new macro? Examples and hints on that would be really
appreciated...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Autoconf-macro-for-gdal-config-tp6907599p6907599.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
