[gdal-dev] Confused about datum transformations
dev4cx4m9z at snkmail.com dev4cx4m9z at snkmail.com
Wed Oct 19 06:09:04 EDT 2011
Well - I have it working, without fully understanding why. I used a SetUTM on each SRS to give it a projection, and all seems OK.  I'm still getting a GEOGCS only for the first SRS (MapSRS) but it doesn't seem to matter.
Some of my map use the "Lambert Conformal Conic" projection. How do I set that instead of UTM?
"GEOGCS["GDA94",DATUM["Geocentric_Datum_of_Australia_1994",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6283"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4283"]"
"PROJCS["UTM coordinate system",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-3],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["Meter",1]]"
"PROJCS["WGS84 Datum",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-3],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["Meter",1]]"
-----Original Message-----
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of dev4cx4m9z-at-snkmail.com |GDAL|
Sent: Wednesday, October 19, 2011 8:21 PM
To: marc.hillman at tpg.com.au; gdal-dev at lists.osgeo.org
Subject: RE: [gdal-dev] Confused about datum transformations
I have a big clue - I have inspected the output of ExportToWKT, and the results are interesting
        With WGS84SRS
            GDALError = .SetProjCS("WGS84 Datum")
            Debug.Assert(GDALError = OGRError.OGRERR_NONE, GetLastErrorMsg())
            GDALError = .SetWellKnownGeogCS("WGS84")          ' Define WGS84 coordinate system
        End With
Produces PROJCS["WGS84 Datum",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"]]]
        With UTMSRS
            GDALError = .SetProjCS("UTM coordinate system")
            GDALError = .SetWellKnownGeogCS("WGS84")              ' Define a UTM coordinate system
        End With
Produces PROJCS["UTM coordinate system",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"]]]
       With MapSRS
            GDALError = .SetProjCS("Map coordinate system")
            GDALError = .ImportFromEPSG(i)
        End With
Produces GEOGCS["GDA94",DATUM["Geocentric_Datum_of_Australia_1994",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6283"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4283"]]
The error when I attempt to create the transformation is always with the SRS that seems to be a projection definition, not a datum. ImportFromEPSG seems to be correctly producing a GEOGCS, but SetWellKnownGeogCS seems to be producing a "PROJCS"
I feel I'm very close to the answer, but I still can't see it.
From: Peter J Halls P.Halls-at-york.ac.uk |GDAL| [mailto:6wyv643jct at sneakemail.com]
Sent: Wednesday, October 19, 2011 7:54 PM
To: marc.hillman at tpg.com.au; dev4cx4m9z at snkmail.com
Subject: Re: [gdal-dev] Confused about datum transformations
A comment from another GDAL user, rather than the development team.
GDAL and OGR are actually C++ tools that have C, Java, Python and other language bindings.  What you have picked up is an artefact of the fact that GDAL is not just C.
The proj4 library for your platform is automatically loaded with GDAL and OGR:
it must be present but no explicit action is required by the user.
Chaitanya's advice was to double check that the transformation parameters are being passed correctly.  Datum transformations *are* fiddly (full stop) to specify and this advice is sound.  You appear to be specifying two parts of the transformation, presumably being content with the default values for the other parameters.  Ideally, you need to get the system to regurgitate its understanding of your parameters in the WKT version of the final transformation specification - ie the complete string.  This is what you are being advised to do.
Problems like this are not confined to GDAL / OGR: I've lost count of the number of times I've handled projection problems here.  What sounds to be a simple operation is not trivial and unpicking problems most often requires an understanding of the transformation method and all the parameters applied.
Hoping that helps,
Peter
dev4cx4m9z at snkmail.com wrote:
> I have not used org2ogr. I have just realised that the C API for GDAL
> uses a mixture of STD and CDECL. How annoying. Anyway – I have
> carefully checked and all are correct. I get a stack balance problem
> if they are not anyway. It’s hard to see how I could get the arguments wrong – one is the string “WGS84”, and the other is an integer.
> I still don’t know whether proj.dll is required.
> From: Chaitanya kumar CH chaitanya.ch-at-gmail.com |GDAL|
> [mailto:5rm5yuc82t at sneakemail.com]
> Sent: Wednesday, October 19, 2011 6:36 PM
> Cc: gdal-dev at lists.osgeo.org
> Marc,
> You don't need to rebuild proj.4; you are already using it.. Since you were able to use ogr2ogr to do the transformation, it works.
> What you need to do is find out if the arguments you are passing to the transformation builder are good. Especially 'MapSRS'. If it doesn't show any problem, plug some debug messages in the OSR code in ogrct.cpp and rebuild gdal.
> On Wed, Oct 19, 2011 at 12:46 PM, <dev4cx4m9z at snkmail.com> wrote:
> Thanks for all the suggestions – they have given me many possibilities to eliminate, but I still haven’t really got an answer to the original question.
> Am I required to have proj.dll built with support for the datums/projections I want to use, or is it sufficient to set GDAL_DATA such that gcs.csv and pcs.csv are visible? I’m working in VB.NET, and I’m not confident I can rebuild PROJ with the required datums, so I wish to avoid if possible. I’d even be prepared to use SetGeogCS explicitly as I only use a few datums. If I use SetGeogCS, I can’t see what purpose proj.dll serves.
> I have set GDAL_DATA to the correct folder.
> I have checked that the datum numbers I use are in the gcs.csv file.
> <mailto:gdal-dev-bounces at lists.osgeo..org> ] On Behalf Of
> Sent: Tuesday, October 18, 2011 4:12 AM
> To: gdal-dev at lists.osgeo.org
> I’m not sure the code will help too much, but here are the relevant
> code fragments. I’m using a hand crafted VB.net wrapper which explains
> some of the syntax
> Private WGS84SRS As New OGRSpatialReference     ' Coordinate system in WGS84
> Private MapSRS As OGRSpatialReference       ' Coordinate system of map
> Private ctWGS84toMap As OGRCoordinateTransformation       ' Coordinate transform from WGS84 to map
> With WGS84SRS
> End With
> With MapSRS
>      GDALError = .ImportFromEPSG(3577)
> End With
> ctWGS84toMap = GDAL.CreateCoordinateTransformation(WGS84SRS, MapSRS)        ' Create a coordinate transformation - WGS84 to map
> Debug.Assert(ctWGS84toMap IsNot Nothing, GetLastErrorMsg())
> Marc,
> Can you provide the code leading to the error?
> On Tue, Oct 18, 2011 at 1:21 PM, Marc Hillman <dev4cx4m9z at snkmail.com> wrote:
> I have a GIS database, and all data is stored in WGS84 datum. I have developed an application using GDAL, and I now need to translate my WGS84 coordinates to several different datums, depending what map is loaded. I seem to be going around in circles, and need a nudge in the right direction. I am defining an OGRSpatialReference for each datum (WGS84 and current map) and then attempting to create an OGRCoordinateTransformation for the transformation.. This last step fails with a PROJ.4 error (“No PROJ.4 translation for destination SRS, coordinate transformation initialization failed”
> My question is - Do I need PROJ.4 to do the translation? Can I not just use ImportFromWKT to define my OGRSpatialReference? If so, is there a nice canned list of all the WKT somewhere?  I’m keen to avoid PROJ.4 if possible as I’m not sure I can build it.
> gdal-dev mailing list
Peter J Halls, GIS Advisor & Team Leader Applications Support and Training,
                Information Directorate, University of York
Telephone: 01904 323806     Fax: 01904 323740
Snail mail: Harry Fairhurst Building, University of York,
             Heslington, York YO10 5DD
This message has the status of a private and personal communication
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.1831 / Virus Database: 2092/4560 - Release Date: 10/18/11
