[gdal-dev] Confused about datum transformations
dev4cx4m9z at snkmail.com dev4cx4m9z at snkmail.com
Wed Oct 19 06:53:44 EDT 2011
Well, it's 'working' (sort of) but I'm still confused. I'll try to explain
better what I'm trying to do.
I have a database of map coordinates stored in WGS84 datum.
I load and display a map in my application which may, or may not, use the
WGS84 datum. I am setting up a coordinatetransformation to convert WGS84
data to whatever datum the map is. I then use another transformation to
translate to screen coordinates.
I'm only worrying about the datum conversion issue first. I will worry about
the map projection issue later.
I have successfully created a number of CT's with no error. When invoked,
they're giving the wrong answer, but I'm still looking into that.
I still don't understand proj.dll. I downloaded the prebuilt proj.dll, and
it seems to only have a few datums. It certainly does not have the ones I'm
using. Does it matter, or must proj.dll contain all the datums I intend to
use? Is the data pointed to by GDAL_DATA sufficient to translate from any
known datum to another?
From: Simon Lyngby Kokkendorff silyko-at-gmail.com |GDAL|
[mailto:r0dk224axt at sneakemail.com]
Sent: Wednesday, October 19, 2011 8:55 PM
To: marc.hillman at tpg.com.au; dev4cx4m9z at snkmail.com
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Confused about datum transformations
Hi Marc,
  Just to understand your problem fully:  You have data in your database in
WGS84, in geographical coordinates, or what? That would correspond to a
srs=osr.SpatialReference(), srs.SetWellKnownGeogCS("WGS84").
   What kind of projection or geographical coordinate system do you want to
project to? It seems to be: EPSG:3557 which is: NAD83(NSRS2007) / Maine
East. Is this correct? If you have the GDAL_DATA env-variable pointing to
the right directory (containing EPSG definitions etc), gdal should be able
to also do:
srs2=osr.SpatialReference(), srs2.ImportFromEPSG(3557), which becomes:
>>> srs2.ExportToPrettyWkt()
'PROJCS["NAD83(NSRS2007) / Maine East",\n    GEOGCS["NAD83(NSRS2007)",\n
DATUM["NAD83_National_Spatial_Reference_System_2007",\n
SPHEROID["GRS 1980",6378137,298.257222101,\n
AUTHORITY["EPSG","7019"]],\n
       TOWGS84[0,0,0,0,0,0,0],\n            AUTHORITY["EPSG","6759"]],\n
PRIMEM["Greenwich",0,\n            AUTHORITY["EPSG","8901"]],\n
UNIT["degree",0.01745329251994328,\n            AUTHORITY["EPSG","9122"]],\n
AUTHORITY["EPSG","4759"]],\n    UNIT["metre",1,\n
AUTHORITY["EPSG","9001"]],\n    PROJECTION["Transverse_Mercator"],\n
PARAMETER["latitude_of_origin",43.66666666666666],\n
PARAMETER["central_meridian",-68.5],\n
PARAMETER["scale_factor",0.9999],\n    PARAMETER["false_easting",300000],\n
PARAMETER["false_northing",0],\n    AUTHORITY["EPSG","3557"],\n
AXIS["X",EAST],\n    AXIS["Y",NORTH]]'
If you want to perform the actual coordinate transformation, besides just
having descriptions of the systems, you'll definitely need to have proj4.dll
somewhere in your system, where gdal can find it (I guess besides gdal.dll
or somewhere in your PATH).
Cheers,
Simon
On Wed, Oct 19, 2011 at 11:21 AM, <dev4cx4m9z at snkmail.com> wrote:
I have a big clue - I have inspected the output of ExportToWKT, and the
results are interesting
       With WGS84SRS
           GDALError = .SetProjCS("WGS84 Datum")
           Debug.Assert(GDALError = OGRError.OGRERR_NONE, GetLastErrorMsg())
           GDALError = .SetWellKnownGeogCS("WGS84")          ' Define WGS84
coordinate system
       End With
Produces PROJCS["WGS84 Datum",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],A
UTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT
["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","432
6"]]]
       With UTMSRS
           GDALError = .SetProjCS("UTM coordinate system")
           GDALError = .SetWellKnownGeogCS("WGS84")              ' Define a
       End With
Produces PROJCS["UTM coordinate system",GEOGCS["WGS
6"]]]
      With MapSRS
           GDALError = .SetProjCS("Map coordinate system")
           GDALError = .ImportFromEPSG(i)
       End With
Produces
GEOGCS["GDA94",DATUM["Geocentric_Datum_of_Australia_1994",SPHEROID["GRS
1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],TOWGS84[0,0,0,0,0,0,0]
,AUTHORITY["EPSG","6283"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UN
IT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4
283"]]
The error when I attempt to create the transformation is always with the SRS
that seems to be a projection definition, not a datum. ImportFromEPSG seems
to be correctly producing a GEOGCS, but SetWellKnownGeogCS seems to be
producing a "PROJCS"
I feel I'm very close to the answer, but I still can't see it.
-----Original Message-----
[mailto:6wyv643jct at sneakemail.com]
Sent: Wednesday, October 19, 2011 7:54 PM
A comment from another GDAL user, rather than the development team.
GDAL and OGR are actually C++ tools that have C, Java, Python and other
language bindings.  What you have picked up is an artefact of the fact that
GDAL is not just C.
The proj4 library for your platform is automatically loaded with GDAL and
OGR:
it must be present but no explicit action is required by the user.
Chaitanya's advice was to double check that the transformation parameters
are being passed correctly.  Datum transformations *are* fiddly (full stop)
to specify and this advice is sound.  You appear to be specifying two parts
of the transformation, presumably being content with the default values for
the other parameters.  Ideally, you need to get the system to regurgitate
its understanding of your parameters in the WKT version of the final
transformation specification - ie the complete string.  This is what you are
being advised to do.
Problems like this are not confined to GDAL / OGR: I've lost count of the
number of times I've handled projection problems here.  What sounds to be a
simple operation is not trivial and unpicking problems most often requires
an understanding of the transformation method and all the parameters
applied.
Hoping that helps,
Peter
dev4cx4m9z at snkmail.com wrote:
> I have not used org2ogr. I have just realised that the C API for GDAL
> uses a mixture of STD and CDECL. How annoying. Anyway - I have
> carefully checked and all are correct. I get a stack balance problem
> if they are not anyway. It's hard to see how I could get the arguments
wrong - one is the string "WGS84", and the other is an integer.
> I still don't know whether proj.dll is required.
> From: Chaitanya kumar CH chaitanya.ch-at-gmail.com |GDAL|
> [mailto:5rm5yuc82t at sneakemail.com]
> Sent: Wednesday, October 19, 2011 6:36 PM
> Marc,
> You don't need to rebuild proj.4; you are already using it.. Since you
were able to use ogr2ogr to do the transformation, it works.
> What you need to do is find out if the arguments you are passing to the
transformation builder are good. Especially 'MapSRS'. If it doesn't show any
problem, plug some debug messages in the OSR code in ogrct.cpp and rebuild
gdal.
> On Wed, Oct 19, 2011 at 12:46 PM, <dev4cx4m9z at snkmail.com> wrote:
> Thanks for all the suggestions - they have given me many possibilities to
eliminate, but I still haven't really got an answer to the original
question.
> Am I required to have proj.dll built with support for the
datums/projections I want to use, or is it sufficient to set GDAL_DATA such
that gcs.csv and pcs.csv are visible? I'm working in VB.NET, and I'm not
confident I can rebuild PROJ with the required datums, so I wish to avoid if
possible. I'd even be prepared to use SetGeogCS explicitly as I only use a
few datums. If I use SetGeogCS, I can't see what purpose proj.dll serves.
> I have set GDAL_DATA to the correct folder.
> I have checked that the datum numbers I use are in the gcs.csv file.
> From: gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org
> <mailto:gdal-dev-bounces at lists.osgeo..org> ] On Behalf Of
> dev4cx4m9z at snkmail.com <mailto:dev4cx4m9z at snkmail..com>
> Sent: Tuesday, October 18, 2011 4:12 AM
> To: gdal-dev at lists.osgeo.org
> Subject: RE: [gdal-dev] Confused about datum transformations
> I'm not sure the code will help too much, but here are the relevant
> code fragments. I'm using a hand crafted VB.net wrapper which explains
> some of the syntax
> Private WGS84SRS As New OGRSpatialReference     ' Coordinate system in
WGS84
> Private MapSRS As OGRSpatialReference       ' Coordinate system of map
> Private ctWGS84toMap As OGRCoordinateTransformation       ' Coordinate
transform from WGS84 to map
> With WGS84SRS
coordinate system
> End With
> With MapSRS
>      GDALError = .ImportFromEPSG(3577)
> End With
> ctWGS84toMap = GDAL.CreateCoordinateTransformation(WGS84SRS, MapSRS)
' Create a coordinate transformation - WGS84 to map
> Debug.Assert(ctWGS84toMap IsNot Nothing, GetLastErrorMsg())
> Marc,
> Can you provide the code leading to the error?
> On Tue, Oct 18, 2011 at 1:21 PM, Marc Hillman <dev4cx4m9z at snkmail.com>
wrote:
> I have a GIS database, and all data is stored in WGS84 datum. I have
developed an application using GDAL, and I now need to translate my WGS84
coordinates to several different datums, depending what map is loaded. I
seem to be going around in circles, and need a nudge in the right direction.
I am defining an OGRSpatialReference for each datum (WGS84 and current map)
and then attempting to create an OGRCoordinateTransformation for the
transformation.. This last step fails with a PROJ.4 error ("No PROJ.4
translation for destination SRS, coordinate transformation initialization
failed"
> My question is - Do I need PROJ.4 to do the translation? Can I not just
use ImportFromWKT to define my OGRSpatialReference? If so, is there a nice
canned list of all the WKT somewhere?  I'm keen to avoid PROJ.4 if possible
as I'm not sure I can build it.
> gdal-dev mailing list
Peter J Halls, GIS Advisor & Team Leader Applications Support and Training,
               Information Directorate, University of York
Telephone: 01904 323806     Fax: 01904 323740
Snail mail: Harry Fairhurst Building, University of York,
            Heslington, York YO10 5DD
This message has the status of a private and personal communication
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.1831 / Virus Database: 2092/4560 - Release Date: 10/18/11
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111019/538539dc/attachment-0001.html
