[gdal-dev] Re: DTED Elevations with Java and gdal
Roger Viton wsureshoot at fastmail.fm
Thu Oct 20 11:14:14 EDT 2011
Grateful for your replies.
Am not fluent yet in all the coordinate systems.
Will learn them though.
We have a DTED dt0 file that has 121*121 data points.
Used geotools to get the elevation at point (1,1).
When gdallocationinfo.exe was run at the same point (1,1)
gdallocationinfo returned the same elevation.
A good sign.
Plan to port the gdallocationinfo.cpp to Java.
Will report back when it is complete.  Maybe someone
else is interested also.
Thank you.
Roger
View this message in context: http://osgeo-org.1803224.n2.nabble.com/DTED-Elevations-with-Java-and-gdal-tp6910385p6913271.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
