[gdal-dev] ReadAsArray with Windows 7
Tamas Szekeres szekerest at gmail.com
Fri Oct 21 14:36:03 EDT 2011
2011/10/21 Frank Warmerdam <warmerdam at pobox.com>
> On Fri, Oct 21, 2011 at 6:34 AM, Discourse Maps <discoursemap at live.com>
> wrote:
> > Hi,
> > I was wondering if the issue mentioned in a past thread has every been
> > addressed.
> http://osgeo-org.1803224.n2.nabble.com/Gdal-Python-Win7-crash-with-ReadAsArray-td4398401.html
> > I am having much the same issues with GDAL 1.6.1, Windows 7, and using
> > 'ReadAsArray'.  Python crashes almost every time.
> > Any help is most appreciated.
> Jimmy,
> It looks like the folks running into the problem were all using
> Tamas' binaries.  Would you be willing to see if you can reproduce
> the problem with the OSGeo4W binaries?  If so, please file a ticket
> against GDAL with all the details and hopefully someone will be
> able to dig into it.
I think it wasn't mentioned which binaries have been used. By reading back
the thread above, it was said an old gdal distribution caused the issue
whereas the daily builds were working:
<quote>
It appears that the official binaries for gdal 1.6 simply do not work on
Win7 x64 while the problem is already fixed in the cutting edge builds
</quote>
Daily builds also do autotests including the use of ReadAsArray()
in numpy_rw.py  and it doesn't seem to be failing.
One issue I have in my mind is a crash with the x64 version of Python +
numpy+ GDAL (in autotests) therefore numpy hasn't been added in the x64
builds.
By all means if someone can prepare a ready to use test case to reproduce
this issue, I'll be happy to do a test with that.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111021/ce5e5110/attachment.html
