[gdal-dev] New mloskot-github-gdal-20111018.7z
Mateusz Łoskot mateusz at loskot.net
Sat Oct 22 09:08:48 EDT 2011
2011/10/21 Mateusz Łoskot <mateusz at loskot.net>:
> On 21 October 2011 07:54, Antonio Valentino
> <antonio.valentino at tiscali.it> wrote:
>> It seems that the svn2git [1] tool (based on git-svn) is able to import
>> svn repositories with branches in a proper way.
>> I never used it an I don't know if it allows to push changes back to
>> svn.
>> Anyway since Julien only needs to generate a patch, svn2git should be
>> good for its purposes.
>> [1] https://github.com/nirvdrum/svn2git
> "(...) This is a one way sync, but allows you to use svn2git as a
> mirroring tool for your SVN repositories."
> Thanks! It looks it is what we need.
> I will try to recreate the mirror using svn2git over the weekend.
I've rebuilt GDAL mirror at GitHub using svn2git.
I hope it's in usable state.
I've also updated the Wiki with the process explanation:
http://trac.osgeo.org/gdal/wiki/UsingGitToMaintainGDALWorkflow#Gitrepositorysetupusingsvn2git
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
Member of ACCU, http://accu.org
