[gdal-dev] Gdal_translate, question from an amateur.
joolek joolek.o at gmail.com
Sat Oct 22 19:10:22 EDT 2011
Hi all,
I need your expertise... I've got number of TIFF's and ECW's with RGB
(72,255,25) that I would like to convert to 255,255,255.
How should the command looks like?.. gdal_translate -scale (not sure about
this) <input> <output>
Thank you guys!!, appreciate any help.
J
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Gdal-translate-question-from-an-amateur-tp6921127p6921127.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
