[gdal-dev] gdal_contour stuck in processing?
Graeme Merrall graeme at inetix.com.au
Sun Oct 23 23:50:04 EDT 2011
Correction, the cmdline was "gdal_contour -a ELEL -i 10.0 dtm.tif
dtm-10m.shp"
On Mon, Oct 24, 2011 at 1:58 PM, Graeme Merrall <graeme at inetix.com.au>wrote:
> Apologies for the delay in replying.
> I ran the same command with 10m spacing "gdal_contour -a ELEL -i 1.0
> dtm.tif dtm-10m.shp" and the same issue occurred.   I also ran the DTM
> through gdal_translate to add projection info just in case. Note this is
> gdal_1.8.1 running on Ubuntu Lucid not from deb's but a custom compile
> The same symptoms occur, it gets to around 7% or so then hangs. Load goes
> through the roof.
> Ran it through strace and seems to get stuck in massive loop with calling
> brk()
> Cheers,
>  Graeme
> On Thu, Oct 13, 2011 at 4:03 PM, Chaitanya kumar CH <
> chaitanya.ch at gmail.com> wrote:
>> Graeme,
>> Can you try again with a much larger interval?
>> On Thu, Oct 13, 2011 at 6:32 AM, Graeme Merrall <graeme at inetix.com.au>wrote:
>>> I'm trying out gdal_contour just to see what falls out of it as an
>>> experiment.  I've noticed it seems to get to "0.."  e.g. 7% or so, and
>>> then seems to hang.  I'm trying it on a relatively small DTM
>>> The cmdline is pretty simple "gdal_contour -a ELEL -i 1.0
>>> dtm_11072101.tif dtm-1m.shp"
>>> and gdalinfo gives the following info  about the image
>>> Driver: GTiff/GeoTIFF
>>> Files: dtm_11072101.tif
>>>      dtm_11072101.tfw
>>> Size is 1000, 2500
>>> Coordinate System is `'
>>> Origin = (488000.000000000000000,7198000.000000000000000)
>>> Pixel Size = (2.000000000000000,-2.000000000000000)
>>> Metadata:
>>>  TIFFTAG_XRESOLUTION=200
>>>  TIFFTAG_YRESOLUTION=200
>>>  TIFFTAG_RESOLUTIONUNIT=3 (pixels/cm)
>>> Image Structure Metadata:
>>>  INTERLEAVE=BAND
>>> Corner Coordinates:
>>> Upper Left  (  488000.000, 7198000.000)
>>> Lower Left  (  488000.000, 7193000.000)
>>> Upper Right (  490000.000, 7198000.000)
>>> Lower Right (  490000.000, 7193000.000)
>>> Center      (  489000.000, 7195500.000)
>>> Band 1 Block=1000x2 Type=UInt32, ColorInterp=Gray
>>> I admit I'm at a loss as to how to proceed/troubleshoot so any
>>> pointers gratefully received. I tried popping it through
>>> gdal_translate to add a projection but it seems to have the same issue
>>> Cheers,
>>>  Graeme
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Best regards,
>> Chaitanya kumar CH.
>> +91-9494447584
>> 17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111024/9c86db5b/attachment.html
