[gdal-dev] ogrinfo and PGeo Driver for .mdb file, on Ubuntu
Eli Adam eadam at co.lincoln.or.us
Mon Oct 24 14:32:16 EDT 2011
Chris,
     There is also another route that may work for PGeo,
http://www.gdal.org/ogr/drv_mdb.html  I recently built that on Ubuntu but
have not used it yet.  It looks like you are close on the other route
though.
HTH, Eli
On Mon, Oct 24, 2011 at 5:35 AM, Chris Green <chris.green at ibstv.co.uk>wrote:
> Hi List****
> I’m hoping someone can help me make ogr work under Linux with the PGeo
> driver, so I can read an ESRI Personal Database .mdb file into Mapserver. I
> can see from old posts that the basic problem is that MDBTools is a bit
> ‘flaky’ and needs a DSN based connection rather than connecting direct to
> the .mdb data.****
> I have been trying to follow the instructions in
> http://www.gdal.org/ogr/drv_pgeo.html . Having installed unixODBC and
> MDBTools, I configured the odbcinst.ini and odbc.ini files as suggested and
> it seems that I have partial success because when I define my datasource in
> odbc.ini like so:****
> [my_pgeo]****
> Description = Sample PGeo Database****
> Driver      = Microsoft Access Driver (*.mdb)****
> Database    = /var/www/vhosts/mydomain.com/httpdocs/data/test.mdb****
> then the command ogrinfo  PGeo:my_pgeo results in the following:****
> INFO: Open of ‘PGeo:my_pgeo’ using driver ‘PGeo’ successful. ****
> Error: syntax error at line:2 col:0****
> I can’t figure out what or where this syntax error can be. I feel that I am
> quite close to success but don’t know how to move forward from here. Can
> anyone point me in the right direction please?****
> Chris ****
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111024/b45490ab/attachment.html
