[gdal-dev] RFC 37: User context data in CPLErrorHandler callbacks
Tue Oct 25 12:26:33 EDT 2011
On 11-10-25 08:20 AM, Howard Butler wrote:
> All,
> I have prepared an RFC to support the implementation of providing user context data in CPLErrorHandling scenarios. I suspect this is a non-controversial proposal with limited applicability and impact for most folks, and I hope to pass the RFC and implement the proposed code in trunk in a week or so.
> http://trac.osgeo.org/gdal/wiki/rfc37_cplerror_userdata
Howard,
I would like to suggest the the CPLGetLastErrorUserData() be renamed something
like CPLGetErrorHandlerUserData().  It is *not* returning the user data
associated with the last error - but instead the user data associated with
the currently in-force error handler.   I'd also suggest that the functions
documentation include a note mentioning it is primarily intended for use from
within error handlers.
You also did not address if/how this will be exposed in SWIG languages.
Best regards,
light and sound - activate the windows | http://pobox.com/warmerda
and watch the world go round - Rush    | Geospatial Software Developer
