[gdal-dev] RFC 37: User context data in CPLErrorHandler callbacks
Daniel Morissette dmorissette at mapgears.com
Tue Oct 25 21:02:41 EDT 2011
On 11-10-25 08:59 PM, Howard Butler wrote:
> Adam Nowaki explored this option, and I put together a patch that implemented it on the ticket. As Even pointed out [1], this approach causes some complications with how CPLSetErrorHandlerEx vs CPLSetErrorHandler works and what it should return.  In the end, it seemed to me as though this might be more trouble than it was worth.
> [1] http://trac.osgeo.org/gdal/ticket/4295#comment:6
Sounds good. If you've explored the option and found that the current
approach was better then that solves the question for me.
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
