[gdal-dev] Renaming a column's name in a Shapefile
Ralf Suhr Ralf.Suhr at itc-halle.de
Fri Oct 28 08:22:30 EDT 2011
ogr2ogr -f "esri shapefile" -sql "SELECT ele, time AS t, magvar,
geoidheigh, name, cmt, desc, src FROM GPS_Project" new.shp GPS_Project.shp
Gr
Ralf
On Freitag 28 Oktober 2011 13:54:37 António Rocha wrote:
> ogr2ogr -sql "SELECT [ele AS ele, time AS t, magvar AS magvar,
> geoidheigh AS geoidheigh, name AS name, cmt AS cmt, desc_ AS desc_, src
> AS src] FROM GPS_Project.shp", new.shp GPS_Project.shp
